rwbreckinridge Posted March 23, 2021 Report Share Posted March 23, 2021 Hey all, I've been noticing an occasional slight "tick" coming from one of my UM400s, and upon further inspection, I've been able to replicate it by squeezing the pack ever so slightly towards the top of the clip (see attached video- edit: here is a Google Drive link if that's easier). Has anyone run into this before? I'm wondering if there's anything I can do to address it or if it will require sending it back to Lectro. Thanks for your thoughts! 1338560681_UM400test.mov Quote Link to comment Share on other sites More sharing options...
jason porter Posted March 23, 2021 Report Share Posted March 23, 2021 Can you remove the belt clip and see if it goes away? I wonder if the screw is touching something when you squeeze it. Another possibility is to open it up and see if anything is touching the case when you squeeze. Quote Link to comment Share on other sites More sharing options...
rwbreckinridge Posted March 24, 2021 Author Report Share Posted March 24, 2021 23 hours ago, jason porter said: Can you remove the belt clip and see if it goes away? I wonder if the screw is touching something when you squeeze it. Another possibility is to open it up and see if anything is touching the case when you squeeze. Good thoughts! I took the clip off and it still does it; carefully taking the unit apart, nothing seemed obviously awry. I may just have to hit up Lectro support, I was just curious if anyone had seen that problem before and had a fix for it. Thank you! Quote Link to comment Share on other sites More sharing options...
