johnchay Posted March 30, 2021 Report Share Posted March 30, 2021 Hello, I've searched this website but haven't found a solution to my issue. Sending 23.98 fps LTC timecode to a Pulse from SD633. The Pulse is connected to the AtomosX via RF signal. As you can see in the photos, all the units are synced perfectly. When I sync the video and audio in post it's off by 4 frames consistently throughout. I was wondering if there was a solution to this where it could be perfectly in sync when matched in post. Thanks! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted March 30, 2021 Report Share Posted March 30, 2021 Just because the devices are displaying identical TC doesn't mean they are attaching that TC address to recordings at exactly the same moment in history. There may be some latency involved, as you discovered. I have not had this issue with a 633, so I wonder if there is some aspect of how the Atmos is laying the TC into its recordings at work here? What does Atmos say about this? Quote Link to comment Share on other sites More sharing options...
TVPostSound Posted March 30, 2021 Report Share Posted March 30, 2021 Am I seeing drop frame on the Ninja?? Or just blurry? Quote Link to comment Share on other sites More sharing options...
johnchay Posted March 30, 2021 Author Report Share Posted March 30, 2021 48 minutes ago, TVPostSound said: Am I seeing drop frame on the Ninja?? Or just blurry? 23.98, no options for drop frame on SD or Pulse. 2 hours ago, Philip Perkins said: Just because the devices are displaying identical TC doesn't mean they are attaching that TC address to recordings at exactly the same moment in history. There may be some latency involved, as you discovered. I have not had this issue with a 633, so I wonder if there is some aspect of how the Atmos is laying the TC into its recordings at work here? What does Atmos say about this? I reached out to Atomos. I’ll report back what they say. Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted March 30, 2021 Report Share Posted March 30, 2021 Just curious, how/why are the files from the Atomos Ninja being used in Post? Nevermind, found it. Enables ProRes Raw capture with smaller, more cost-effective, mirrorless cameras Quote Link to comment Share on other sites More sharing options...
johnchay Posted March 31, 2021 Author Report Share Posted March 31, 2021 Here is the response from Atomos, Quote Jonathan Fernandez (ATOMOS) Mar 31, 2021, 4:56 GMT+10 Hey John, Thank you for submitting this ticket, We're sorry to hear you're experiencing issues with your device. Do you have Pre Roll enabled? if so I would recommend turning this feature off.( you can find this in your "Media" menu) In you audio menu we have an option for Audio Delay I recommend using this to get your audio and video in sync. ( you can find this in your "Audio" menu) Regards, I'll try adjusting the timecode offset on the ninja V see if that works. Quote Link to comment Share on other sites More sharing options...
