Wandering Ear Posted Wednesday at 06:27 PM Report Share Posted Wednesday at 06:27 PM Is there a contract rate for Music Playback operators? I didn't see the position specifically listed in the ASA, so mostly wondering where they usually fall. Also, if a sound utility operates playback for a scene, would that re-rate them for the day, assuming the playback rate is higher? Quote Link to post Share on other sites
ryanpeds Posted Wednesday at 10:11 PM Report Share Posted Wednesday at 10:11 PM 3 hours ago, Wandering Ear said: Is there a contract rate for Music Playback operators? I didn't see the position specifically listed in the ASA, so mostly wondering where they usually fall. Also, if a sound utility operates playback for a scene, would that re-rate them for the day, assuming the playback rate is higher? Under the ASA most playback Operators fall under the VTR category even though they aren’t the same thing. I usually try to get the same rate as the mixer although sometimes it’s just a little less. A utility should re rate to playback if that’s what they are doing however, you should hire a person specifically for that job. If your utility does it then you should get a different utility for that day, IMHO. Quote Link to post Share on other sites
Wandering Ear Posted Thursday at 04:09 PM Author Report Share Posted Thursday at 04:09 PM Thanks for the info Ryan. I'm not sure hiring additional personnel makes sense for just a single scene in a day. Do you remember when re-rating kicks in? Is it after 2 hours? Quote Link to post Share on other sites
