MGRK Posted May 22, 2021 Report Share Posted May 22, 2021 I have recently purchased the DCHT/DCHR as a camera hop (digital TX and RX also new to me) Is it possible to get line level analogue out of the DCHR, when running AES into the DCHT ? Is it best to run these units on the most recent firmware ? Quote Link to comment Share on other sites More sharing options...
RunAndGun Posted May 22, 2021 Report Share Posted May 22, 2021 AES and analog are switchable on both the receiver and transmitter. There is nothing that I saw in either manual that states that the inputs and output signals have to match. Which to me reads as you can run an AES signal into the Tx and analog out of the Rx, analog into the Tx and AES out of the Rx, AES into the Tx and out of the Rx or analog into the Tx and out of the Rx. Basically you can run analog or digital IN and analog or digital OUT, independently of each other. Quote Link to comment Share on other sites More sharing options...
karlw Posted May 24, 2021 Report Share Posted May 24, 2021 MGRK, yes - as RunAndGun explains, you can independently set the input and output type in each unit. The transmission itself is digital, but you can decide what source or load types you want the system to do. In terms of firmware, it is always advisable to update to the latest version, so that documentation matches, features match, etc. between units. You can always check your firmware versions here: https://lectrosonics.com/firmware/category/157-digital-camera-hop-series-firmware.html Quote Link to comment Share on other sites More sharing options...
MGRK Posted May 31, 2021 Author Report Share Posted May 31, 2021 Thanks all for your comments. I'm finding that with AES into the DCHT, I'm not quite getting analogue line level +4dBu out from the DCHR but I'll check that again (therefore having to increase the analogue input gain on the camera) I agree the manual doesn't refer to it. Quote Link to comment Share on other sites More sharing options...
