tonvogt Posted June 1, 2021 Report Share Posted June 1, 2021 Hello everyone! On my next movie there will be a lot of phone calls inside a car. They go either to a normal phone or to the speakerphone of the car. Although most of the dialogue of the callers will be replaced by different actors in the end, I still need to be able to record the signal and send it to my ifbs. Is there a special piece of equipment I could use? Something to put between a headset and a cellphone to split the signal going in? My other thought would be to use a third phone and use a groupcall function but that would mean, that I will get the signal of both ends and I only want the one from the caller. Any ideas? Greetings and thanks in advance Manuel Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted June 1, 2021 Report Share Posted June 1, 2021 See this recent thread https://jwsoundgroup.net/index.php?/topic/2969-recording-cell-phone-conversations/ Quote Link to comment Share on other sites More sharing options...
edward chick Posted June 1, 2021 Report Share Posted June 1, 2021 Hi tonvogt. Not sure if this helps but when I work live shots I use a cellphone for IFB conntction to the control room/programming. I route the cellphone into my mixer then send the feed to the correspondent’s IFB via an aux out. I take it out of the main mix so it does not go over the air. The cellphone input is on it’s own track and can be recorded. I never need to do that for live tv, but it’s an option. Quote Link to comment Share on other sites More sharing options...
