I was just using my wireless lavs (sony uwp-d) and getting some cable noise. Mostly its because the minijack or the connector is failing.
I replaced the unit, but I cannot replicate it.
I can wiggle the connector and the antenna and nothing happens.
The only reason I can see is, that maybe the connector wasnt screwed in properly, but I checked it on location.
Any other idea?cable noise.wav
The connector in the unit might be defective.
It could also be a break somewhere in the cable that is effective in a certain bending situation.
  • 1 month later...
 I discovered this by accident YEARS ago with a Sony 77, check the top of the lav(the cap) and make sure it is screwed on completely.  I had one that had gotten loose and I thought I had a bad lav or cable or connection.
