Sound Posted June 4, 2021 Report Share Posted June 4, 2021 I was just using my wireless lavs (sony uwp-d) and getting some cable noise. Mostly its because the minijack or the connector is failing. I replaced the unit, but I cannot replicate it. I can wiggle the connector and the antenna and nothing happens. The only reason I can see is, that maybe the connector wasnt screwed in properly, but I checked it on location. Any other idea?cable noise.wav Quote Link to comment Share on other sites More sharing options...
DanieldH Posted June 4, 2021 Report Share Posted June 4, 2021 The connector in the unit might be defective. It could also be a break somewhere in the cable that is effective in a certain bending situation. Quote Link to comment Share on other sites More sharing options...
Andy Munitz Sony Posted July 9, 2021 Report Share Posted July 9, 2021 Are you using the supplied UWP-D lav, or another lav? Quote Link to comment Share on other sites More sharing options...
Sound Posted July 9, 2021 Author Report Share Posted July 9, 2021 It’s the supplied lav. But maybe it was even the connector from the receiver. Quote Link to comment Share on other sites More sharing options...
RunAndGun Posted July 9, 2021 Report Share Posted July 9, 2021 I discovered this by accident YEARS ago with a Sony 77, check the top of the lav(the cap) and make sure it is screwed on completely. I had one that had gotten loose and I thought I had a bad lav or cable or connection. Quote Link to comment Share on other sites More sharing options...
