nevo Posted June 24, 2021 Report Share Posted June 24, 2021 I purchased the cedar SDNX and have been using it with a processed and unprocessed track double I usually only use 1-2 dB of reduction , which I select on each channel. i want to put it on a buss for IFB and can’t figure how to select amount..... Any clues ...I’ve gone to buss output masters but there is no amount selection Quote Link to comment Share on other sites More sharing options...
rich Posted June 24, 2021 Report Share Posted June 24, 2021 assign noise assist to your chosen bus. in the bus assign page, select more... then you can find the noise assist amount. and with the output you want to use to send you IFB, assign your chosen bus. Quote Link to comment Share on other sites More sharing options...
nevo Posted June 24, 2021 Author Report Share Posted June 24, 2021 There’s 2 pages of “more“ You have to toggle 2x to get to the CEDAR. Thanks Rich I may never have found that. Quote Link to comment Share on other sites More sharing options...
