seth Posted July 11, 2021 Report Share Posted July 11, 2021 Hi I found the wiring for red 5pin xlr. I'm Wondering if I can wire the LR receiver Ta3 mono to a 5pin xlr out to both Red channels as client likes to playback most takes. Having both speakers playing on monitor would be more "professional" though I understand it would not give me that much more volume. I'm unclear of phases issues with this kind of wiring. Thanks Quote Link to comment Share on other sites More sharing options...
RunAndGun Posted July 12, 2021 Report Share Posted July 12, 2021 Yes. That’s pretty easy(L & R TA3 to single 5-pin “stereo” XLR). Remote/Trew can knock that out, no problem(I’ve had them build custom cables with left & right TA3 cables to feed out of SR receivers to way more “unconventional” single connections than that). I think they may be caught-up now. They were running about a month out on custom jobs, when I had some cables built a little while back, because of a big order they already had. Quote Link to comment Share on other sites More sharing options...
seth Posted July 12, 2021 Author Report Share Posted July 12, 2021 Thanks but I wanted to make it myself. I'm looking for wiring confidence confirmation as I don't have a way to test the cable except on set. In theory I think there shouldn't be any phase cancelation issue 😑. Sending same signal to two channels usually just gives a volume bump, but has phased each-other out in circumstances that escape me at the moment. I used to do installations with Bose "mono" L1 systems and sometimes a y cable would cancel out the center in a mix. Quote Link to comment Share on other sites More sharing options...
Conor Posted July 12, 2021 Report Share Posted July 12, 2021 Why do you think there may be phase cancellation? I also don't understand why you say: 8 hours ago, seth said: Sending same signal to two channels usually just gives a volume bump, but has phased each-other out in circumstances that escape me at the moment. It sounds like you are confusing splitting with summing? The cable should work fine as described in your OP. Quote Link to comment Share on other sites More sharing options...
