Eric Lau Posted August 19, 2021 Report Share Posted August 19, 2021 what is the maximum AES can run on SD Scorpio? I use Lectrosonics Octopack, Zaxcom QRX200. for example: XLR provide 6 AES, SL6 provide 6 AES, SL2 provide 4 AES, the XL-AES provide 8 AES, Quote Link to comment Share on other sites More sharing options...
Mungo Posted August 19, 2021 Report Share Posted August 19, 2021 I guess in total 12 channels: 4 channels (XLR 1 and 6) + 8 channels (XL-AES 4x TA3) If you need more, use Dante. Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted August 19, 2021 Author Report Share Posted August 19, 2021 CL6 is stop manufacturing, hopefully it will has something new for 12 channels with AES for replacement 😬 Quote Link to comment Share on other sites More sharing options...
yizhye20 Posted August 28, 2021 Report Share Posted August 28, 2021 On 8/19/2021 at 2:52 PM, Mungo said: I guess in total 12 channels: 4 channels (XLR 1 and 6) + 8 channels (XL-AES 4x TA3) If you need more, use Dante. can all 6 xlr run on aes? I thought it was only 1 and 6 Quote Link to comment Share on other sites More sharing options...
Mungo Posted August 29, 2021 Report Share Posted August 29, 2021 12 hours ago, yizhye20 said: can all 6 xlr run on aes? I thought it was only 1 and 6 You're right. But each can run 2 channels of audio Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted September 6, 2021 Author Report Share Posted September 6, 2021 On 8/29/2021 at 2:04 PM, Mungo said: You're right. But each can run 2 channels of audio how to setup in SD menu? Quote Link to comment Share on other sites More sharing options...
Mungo Posted September 6, 2021 Report Share Posted September 6, 2021 I (unfortunately) haven't got access to a Scorpio, but I looked up the user guide: Go to Channel Input Menu and you can select AES 1,2,5,6. Means to me: 2 channels each on XLR 1 and 6. Quote Link to comment Share on other sites More sharing options...
Constantin Posted September 9, 2021 Report Share Posted September 9, 2021 Yes, you select AES just lime you would select any input. If you have the SL-2 or XL-AES add-ons you get more AES inputs if needed Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted October 4, 2021 Author Report Share Posted October 4, 2021 On 9/9/2021 at 6:03 PM, Constantin said: Yes, you select AES just lime you would select any input. If you have the SL-2 or XL-AES add-ons you get more AES inputs if needed I'm thinking to run digital on AES or Dante, what do you think for Lectrosonics wireless? Quote Link to comment Share on other sites More sharing options...
VASI Posted October 6, 2021 Report Share Posted October 6, 2021 On 10/4/2021 at 7:01 PM, Eric Lau said: I'm thinking to run digital on AES or Dante, what do you think for Lectrosonics wireless? Which line? Recently I had an exceptional experience with Venue2 Receiver (and VR Field - the old one) - SMQV Transmitter - ALP650LE Antenna. I have not experience with Digital, yet. Range was impressive with Digital Hydrid. Quote Link to comment Share on other sites More sharing options...
Constantin Posted October 6, 2021 Report Share Posted October 6, 2021 It depends in On 10/4/2021 at 6:01 PM, Eric Lau said: I'm thinking to run digital on AES or Dante, what do you think for Lectrosonics wireless? It depends on which receiver you‘ll want to buy, of course. If you have lots of AES devices, you may want to add a Dante device before you run out of inputs. AES may be simpler, because you don’t need a computer to set it up initially. In terms of sound quality I don’t think there will be any difference. Dante has the advantage of needing only one cable, so there’s that… Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted October 10, 2021 Author Report Share Posted October 10, 2021 On 10/6/2021 at 5:20 PM, VASI said: Which line? Recently I had an exceptional experience with Venue2 Receiver (and VR Field - the old one) - SMQV Transmitter - ALP650LE Antenna. I have not experience with Digital, yet. Range was impressive with Digital Hydrid. I don’t know any change of the distance of range, but I can tell the digital (aes and Dante) will has better sound than analog (wireless) On 10/7/2021 at 4:04 AM, Constantin said: It depends in It depends on which receiver you‘ll want to buy, of course. If you have lots of AES devices, you may want to add a Dante device before you run out of inputs. AES may be simpler, because you don’t need a computer to set it up initially. In terms of sound quality I don’t think there will be any difference. Dante has the advantage of needing only one cable, so there’s that… Great explanation, then I will go aes, I don’t want to bring the computer onset, try to limit the equipment, you know. Only two person in sound department onset in Hong Kong, sound recordist and boom operator. Producer won’t pay extra.🥲🥲 Quote Link to comment Share on other sites More sharing options...
Constantin Posted October 12, 2021 Report Share Posted October 12, 2021 On 10/10/2021 at 3:19 AM, Eric Lau said: I don’t know any change of the distance of range, but I can tell the digital (aes and Dante) will has better sound than analog (wireless) Great explanation, then I will go aes, I don’t want to bring the computer onset, try to limit the equipment, you know. Only two person in sound department onset in Hong Kong, sound recordist and boom operator. Producer won’t pay extra.🥲🥲 No need for the computer on set. You only need to make your Dante connections with a computer once. When you‘ve done that, you can leave your computer at home. After a firmware update you may have to repeat. Quote Link to comment Share on other sites More sharing options...
