Sound Posted September 26, 2021 Report Share Posted September 26, 2021 Hi everyone. For the first time I have a massive recording issue with the new BP-TRX Audio recorder. As always I synced the files with my video in Post, but the file from one transmitter/recorder shows a duration of zero seconds in tentacle sync studio, although it can be played back perfectly fine in VLC and timecode can be read from tentacle sync. In LTCconvert I cannot even import the file. File size on both recorders is about the same, so the file should be ok. What can I do to make it readable again and keep the embedded timecode?? Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 26, 2021 Report Share Posted September 26, 2021 Have you tried Wave Agent? Can you open the file in a DAW (Reaper etc)? If so can the DAW see the file TC? Quote Link to comment Share on other sites More sharing options...
Sound Posted September 27, 2021 Author Report Share Posted September 27, 2021 No chance in Wave Agent. I tried to import in Final cut, no chance. Today I did a low format on all cards and tried it again. But this time, five of my eight files are corrupt. The whole shoot is completely ruined. This thing is absolutely unreliable, I will have to return it. Quote Link to comment Share on other sites More sharing options...
Sound Posted September 27, 2021 Author Report Share Posted September 27, 2021 Avid and Resolve can Import, but show no duration and cant play it back. Logic Pro cant recognize the file. And apple compressor says failed: 3x CAVFmedia:: duration: no valid samples. Guess I am completely screwed. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted September 27, 2021 Report Share Posted September 27, 2021 In audacity, you can open the sound as .raw audio data, which means that it will only read the audio of the file, then you can export it to a new wav file but the timecode will be stripped, of course. I'm guessing what's happened is that the bptrx hasn't successfully written the Metadata correctly into the file. If you decide to give audacity a try, know that in order for the raw audio to sound correctly you need to know the exact bit and sample rate, otherwise it'll just produce noise. Also, if you can somehow resolve the first frame timecode, you can amend the missing timecode in wave agent after recovering the audio, iirc If you feel burned, I'd be happy to help. Send me a DM if so Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted September 27, 2021 Report Share Posted September 27, 2021 Ya, I've used Audacity to "uncorrupt" audio files that got corrupted when the recorder was turned off or lost power before the file header was written as it would be if the file was closed/saved normally (I wonder if something like that happened with your transmitter/recorder). Audacity is free and straightforward; it's available here: https://www.audacityteam.org But if you're feeling wiped and don't want to send the files to Olle (awesome offer of help Olle!), you could try VLC since you already have and are familiar with it. I just googled up this YouTube tutorial. It's from a few years ago, but turns out it's done by a friend who owns a software company. Anyway, he shows some WAV files with zero duration, so perhaps it's a similar issue to what you're facing. And the video has almost 50,000 views; this is a common problem... If nothing else, a quick try with VLC might put your mind at ease before you try Audacity + Wave Agent as Olle suggests. Good luck. Quote Link to comment Share on other sites More sharing options...
Sound Posted September 27, 2021 Author Report Share Posted September 27, 2021 Thanks both of you! I already exported the audio via vlc with the setting „keep audio“, so everything should stay unchanged. Then I readied the tc with wave agent and synced it to the video with tentacle sync studio. But suddenly there was massive audio drift. Towards the end of one audio file it was about three seconds I guess. So maybe vlc got the wrong sample rate and I should try again with audacity, where I can set the sample Rate if I got it correctly.. Still I don’t think I can trust the internal recording of the transmitters anymore.. hope there will be a solution. Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted September 27, 2021 Report Share Posted September 27, 2021 Glad that you have audio files again! Bummer that it's going to take some work to get everything TC'd and sync'd. But still... Maybe drop Deity a note and asked them what might have caused the issue. My guess is power lost or turned off before the files finished writing. But Deity might have some better thoughts...and perhaps a way to avoid or minimize the problem in the future. No idea if there is a solution, but worth at least asking. https://deitymic.com/support/ Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 I already contacted them two days ago, when there was only one corrupt file. Unfortunately I had to use them again the next day. First I thought maybe its a corrupt sd card and I did a low format on all cards. But now theres a massive problem on all recorders. I was careful and stopped recording before switching them off, although i would expect a device to store recorded files properly when switching off while recording I am afraid I have no chance in audacity. I tried both 24 bit settings annd entered 48000 khz, but theres only noise coming out. Strange, that all the metadata seems available in mediainfo and tentacle sync, including the starting timecode, but no file duration. Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 DWVW is the other 24 bit setting, but only available in mono, so no chance for stereo files. Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted September 28, 2021 Report Share Posted September 28, 2021 I wasn't thinking you powered off incorrectly, but rather that maybe the tx/recorder somehow dropped power for short period. Like there's a faulty switch or something. No real idea. Total drag. For me, once I get an error on a card, I ditch it. I don't try to resurrect it or have bad sectors (or whatever) mapped out. The things are comparatively cheap, and the aggravation a bad card causes...well, you know. Again, total bummer. Hang in there! Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 You are right. Still I dont know if the card is the problem, they are quite new and it happened on both recorders - on two different cards. I just checked and shut down both of them two times while recording. No corrupt files. So maybe it has to do with the duration of the recording... With the mixpre 10 ii I never had a single corrupt file, now switching to those recorders seems a huge risk. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted September 28, 2021 Report Share Posted September 28, 2021 Tried importing into reaper? Tried importing normally into audacity? I too find vlc a bit tedious to use, a lot of trial and error and just by chance it'll work. Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 Just ordered two new cards as well, but I guess I will not rely on the internal recording anymore. Ordered a Zoom F6 as well to record a backup. Its a pity that the wireless connection of the deity is not that reliable, so I cannot use them as transmitters for the f6 with internal backup recording. I will switch back to my sony uwp-d.. I guess 3 minutes ago, Olle Sjostrom said: Tried importing into reaper? Tried importing normally into audacity? I too find vlc a bit tedious to use, a lot of trial and error and just by chance it'll work. I dont use reaper, but if I import normally, there is no waveform and no playback.. so I guess i have to stick to vlc. Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted September 28, 2021 Report Share Posted September 28, 2021 You could try Reaper. It's a free download, and for these purposes it's easy enough to use. Sometimes it's a pure problem solver Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 thanks again! Reaper batch conversion works and can even keep the timecode. Still the massive audio drift remains. But at least I dont have to dial in the timecodes manually and conversion is much quicker as with vlc - where i have to convert file by file. Quote Link to comment Share on other sites More sharing options...
Bouke Posted September 28, 2021 Report Share Posted September 28, 2021 Send one to me. If the data is there, I can fix it. Bouke Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 Just now, Bouke said: Send one to me. If the data is there, I can fix it. Bouke I can fix the file, but there is audio drift. Do you think you can fix it without drift? Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 And thanks for the help again!! How can I send it? Quote Link to comment Share on other sites More sharing options...
Bouke Posted September 28, 2021 Report Share Posted September 28, 2021 Using my WeTranfer (here) I think the Data chunk is set to 0. Setting it to FFFFFFFF (if it's < 4 gig) should do the trick, or calculate the 'right' size. What happens with drift. If the timestamp is there, there should be no drift. I know that for Avid you can force the FPS. (Thus Avid won't ask how to interpret the timestamp.) That's an easy fix as well, in the Bext chunk, remove the Speed (pad with space) (Perhaps also comment out the iXML, if it's present) Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 Thanks! You know what you are talking about! But sounds a little complicated to me. How do you know, where the drift is going? And how can I remove the speed? I sent you the files 46 minutes ago, Bouke said: That's an easy fix as well, in the Bext chunk, remove the Speed (pad with space) (Perhaps also comment out the iXML, if it's present) By the way, i just checked: I can recreate the problem, when I pull out the card while recording. Exactly the same then: Large file with zero duration. Maybe the contacts of the internal sd card reader loose contact after some time. In the first weeks I had no problems at all with the same micro sd card. (sandisk extreme). Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 Hi Bouke, thanks again for your help!! We canceled the project now, so no worries - I dont need the footage anymore. But If you know a good workaround if it happens again, let me know! Quote Link to comment Share on other sites More sharing options...
Sound Posted September 28, 2021 Author Report Share Posted September 28, 2021 I tried Samsung Evo cards now, exactly the same problem. The first file I recorded is already corrupt. Quote Link to comment Share on other sites More sharing options...
daniel Posted September 28, 2021 Report Share Posted September 28, 2021 5 hours ago, Sound said: I tried Samsung Evo cards now, exactly the same problem. The first file I recorded is already corrupt. Have you tried contacting Deity customer support? And if so how was it? Quote Link to comment Share on other sites More sharing options...
Sound Posted September 29, 2021 Author Report Share Posted September 29, 2021 10 hours ago, daniel said: Have you tried contacting Deity customer support? And if so how was it? They said it must be the sandisk card because all recording problems have been reported with these cards. So I had to get Samsung cards, and it’s exactly the same. Haven’t received an answer so far. Sounded like they don’t know another solution. I think the problem shows more frequently when you record a long take, about an hour and than stop and immediately start recording remotely via the receiver. Like the Transmitter has no time to write the data in the recorded file. But i am not sure. Quote Link to comment Share on other sites More sharing options...
