Ambience recording for cinema-surround
Sebi
Hi everybody :)
I've been wondering if there's someone out there who could give some advice on field-recordings specifically for cinema. I've learned and experienced myself that correlated stereo/surround setups tend to fall apart in a mix since 90 % of the audience are not sitting in the "sweet spot". But still I find a lot of field-recordings are done with an MS/DMS setup. I can totally see why considering how compact and fast it is. Maybe the only chance to do on-set ambience at all.
But maybe there are some opinions also from a post-perspective on which setup works best for this kind of situations. For the next project I get the chance to come back to the location to record ambiences.
I used to de-correlate stereo recordings by just duplicating and dragging the clips around so that I end up with a quadrophonic ambience. It works fine mostly but depends on the content of the ambience.
Also, do you usually use 5 channels for cinema ambiences or do you work quadrophonic only?
Thanks a lot!
Sebi
