Jim Feeley Posted September 30, 2021 Report Share Posted September 30, 2021 I'm looking for a small plate or holder that will help me mount a TC box (I have Denecke JB-1s and Tentacles) or perhaps a G3-sized RX to camera cages/plates 1/4-inch and/or 3/8-inch mounts. There is a bracket made for Tentacle Sync Es, but Denecke didn't have any recommendations. So I turn to all of you: What do you use to mount TC boxes (especially) to cameras besides velcro and such? There's this bracket made by Lanparte for Tentacle Sync E. Sizing is a smidge different from JB-1 sizing. But does anyone have first-hand knowledge on if you can wedge a JB-1 into this? https://shop.tentaclesync.com/product/sync-e-bracket-by-lanparte/ There's this SSD holder from SmallRig. It might maybe sorta fit a JB-1 Again, any first-hand experiences with it? https://www.smallrig.com/smallrig-universal-holder-for-external-ssd-bsh2343.html And there's this small-device holder from Vocas, though it's a bigger platform than I need for TC (though might be a good size for RX. https://www.vocas.com/vocas-small-device-holder.html I have a hazy memory of something similar from K-Tek or someone. But what am I forgetting? Note: I'm not looking for cold shoe mounts. Any warnings or recommendations? Esp with things you've used that didn't or did work? Quote Link to comment Share on other sites More sharing options...
codyman Posted October 1, 2021 Report Share Posted October 1, 2021 I use Sennheiser CA2 Shoe Mounts. They have 3/8" threads on the bottom or can go into a hot/cold shoe. I've put soft side velcro all over the topside of it and I've successfully mounted a G3 receiver (for scratch utilizing my IFB signal off my IFBT4 transmitter) and a JB-1 side by side on it. It's tight with both next to each other but using the heavy duty velcro branded stuff holds it all fine. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted October 1, 2021 Report Share Posted October 1, 2021 13 minutes ago, codyman said: I use Sennheiser CA2 Shoe Mounts. They have 3/8" threads on the bottom or can go into a hot/cold shoe. I've put soft side velcro all over the topside of it and I've successfully mounted a G3 receiver (for scratch utilizing my IFB signal off my IFBT4 transmitter) and a JB-1 side by side on it. It's tight with both next to each other but using the heavy duty velcro branded stuff holds it all fine. This. I have various solutions I made myself, mostly for larger "Lockit" type TC+Trilevel boxes that can clamp to various camera parts (incl. pan handle) but the Senny shoe mounts have worked great on small cameras if they have a shoe. It helps that I still use Senny RX for cams (which securely attach to the shoe mount), then mini TC boxes can velcro+bongo to the RX. Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted October 2, 2021 Author Report Share Posted October 2, 2021 23 hours ago, codyman said: I use Sennheiser CA2 Shoe Mounts. They have 3/8" threads on the bottom or can go into a hot/cold shoe. I've put soft side velcro all over the topside... Thanks. Excuse my denseness, so with the CA2, you can stick a 3/8 bolt through the bottom of the plate or use it's built-in 3/8 bolt and get a fairly sleek mount onto a 3/8 socket? That'd be groovy! Jim PS- I have few shoe-mount things, but I'm finding the shoes less available these days. Is that just me? Quote Link to comment Share on other sites More sharing options...
Paul F Posted October 2, 2021 Report Share Posted October 2, 2021 The CA2 has a 1/4-20 nut inside the shoe (not 3/8"). It's not a through-hole so it won't take a long screw. There is no screw on the CA2, only a nut. The shoe is mounted to the plate by a phillips screw. It can be relocated in several places on the plate or removed. Quote Link to comment Share on other sites More sharing options...
Jim Feeley Posted October 6, 2021 Author Report Share Posted October 6, 2021 Thanks everyone. I ordered a Sennheiser CA2... If it doesn't work out of the box, it looks like I can mod it. If I come up with anything both clever and useful, I'll post a picture here... Quote Link to comment Share on other sites More sharing options...
Paul F Posted October 6, 2021 Report Share Posted October 6, 2021 Here's something interesting - https://www.etsy.com/listing/945075647/3d-printed-cage-mount-for-tentacle-sync I found these printed solutions. If any of them appeal to you, take the file to your local library and print it. Many local libraries have 3D printing capability. https://www.thingiverse.com/thing:4623420 https://www.thingiverse.com/thing:3644802 https://www.thingiverse.com/thing:2945331 https://www.prusaprinters.org/prints/67460-cold-shoe-mount-for-tentacle-sync-e Quote Link to comment Share on other sites More sharing options...
