Clipping is the concern right now because I cannot set gain manually. It just doesnt seem to set the gain according to the asymmetric waveform..
Its always the same, when I try it again..
What hardware is this recorded with?
Asymmetric = DC offset which can be removed with a highpass filter (even a 12db/oct from 30hz).
Maybe the offset is throwing the autogain off into clipping on one side
