joi b Posted October 24, 2021 Report Share Posted October 24, 2021 Sunday project just works - does not enter the case, and is removable in 2 minutes if you need to Quote Link to comment Share on other sites More sharing options...
DanieldH Posted November 12, 2021 Report Share Posted November 12, 2021 Nice project. I have a similar construction on my first cart. The thing with these pipe solutions is, that they they are sometimes a bit annoying in low ceilings. I use them now just as a small cup for the bottom end of the boom. The perfect clamp upwards is yet to be found. Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted November 12, 2021 Report Share Posted November 12, 2021 1 hour ago, DanieldH said: Nice project. I have a similar construction on my first cart. The thing with these pipe solutions is, that they they are sometimes a bit annoying in low ceilings. I use them now just as a small cup for the bottom end of the boom. The perfect clamp upwards is yet to be found. I used these: https://quickfist.com/quick-fist-clamp.html Quote Link to comment Share on other sites More sharing options...
DanieldH Posted November 12, 2021 Report Share Posted November 12, 2021 I know them and worked with those, very good and common, yet not perfect, as you need some extra time to secure when in a rush. Quote Link to comment Share on other sites More sharing options...
Paul F Posted November 13, 2021 Report Share Posted November 13, 2021 These are the perfect upper clamp. They come in different sizes. Bought these at the local hardware store. Was advised about these from others on this forum. Push in and it locks in place. Pull out and go. Very nice. This is a UK link, but I found them in the States as well. https://www.grippatank.co.uk/gripparack-rubber-pole-mount-suitable-for-10-35ft Quote Link to comment Share on other sites More sharing options...
Rachel Cameron Posted December 14, 2021 Report Share Posted December 14, 2021 Baja Edd deserves a mention here. Been using them on my bag cart for years. Love them. Durable and easy to mount. I like the side opening "C" shaped versions better than the other version with the middle opening. One hand operation with a twist of the wrist. Quote Link to comment Share on other sites More sharing options...
bcopenhagen Posted February 6, 2022 Report Share Posted February 6, 2022 Joi b- You say the silver pipes clamp doesn’t penetrate the Pelican case. How does it attach to the case ? Thanks, Brian Quote Link to comment Share on other sites More sharing options...
igomarsound Posted May 16, 2022 Report Share Posted May 16, 2022 On 10/24/2021 at 6:17 PM, joi b said: Sunday project just works - does not enter the case, and is removable in 2 minutes if you need to nice stuff. i'm also interested knowing your technique on how you installed these clamps without drilling an hole in the pelicase. thanks for sharing Quote Link to comment Share on other sites More sharing options...
