jawharp Posted November 2, 2021 Report Share Posted November 2, 2021 Hey guys, I was looking at the manual for the Cooper 106+1 to read about the optional stereo channel you can put into the 7th slot. At first I thought the 7th slot could only take either an aux module or a stereo module, but the description for the stereo module says it was designed to be used at any channel on the board. Does that mean you can put an extra mono track into the 7th slot and gain another mono channel? The wording was a bit confusing. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
Axel Mishael Posted November 3, 2021 Report Share Posted November 3, 2021 Hi Joe, You can put an extra mono on the 7th or the Stereo Module and use it as mono which is how I use it. Axel. Quote Link to comment Share on other sites More sharing options...
jawharp Posted November 7, 2021 Author Report Share Posted November 7, 2021 Okay, so I got an extra mono channel from Trew's used section. It looks like it's in good condition, but I just realized I don't have the XLR or TRS direct out jacks for the rear panel of the mixer. I can get those no problem, but I'm wondering how complicated it is to wire them in. Do they attach to the body of the mixer internally? Or to the module somewhere? The 106+1 manual wasn't very descriptive in how to add the jacks to the holes that normally come covered on the back panel. Has anyone had any experience adding channels to 106+1's that can give any info on how adding the jacks is accomplished? Thanks, Joe Quote Link to comment Share on other sites More sharing options...
