Daisy chain guitar pedal cables for a charging case DC distro
DanieldH
  • 4 weeks later...
https://www.powerstream.com/Wire_Size.htm
Just glancing at a few – it looks like they are 24 gauge, which has a max current of 3.5amps in chassis wiring, and half an amp for power transmission. (In a charging case, I think you can lean more towards the chassis wiring specification, but I believe they shouldn't be paired in that configuration, just free wires.)
So the rating says no, but you can try it, and if it melts then you know for sure you undersized your wires
