Trey Posted December 9, 2021 Report Share Posted December 9, 2021 I am currently modifying my Olympia Tools 85-188 cart. I removed one of the side handles (there are bushings that go through the plastic handle that you will need to remove before the handle will come off). And I found some caps that fit the tube perfectly! https://www.amazon.com/4pcs-Pack-Plastic-Furniture-Finishing/dp/B07PSNYLN6/ref=sr_1_7?keywords=30mm+pipe+cap&qid=1639074510&sr=8-7 I removed the handle so that I could mount a "Quick Fist" clamp to the top shelf without the handle being in the way. Also I am building a little cup that will slip on the lip of the bottom shelf. I will post photos of it after it is finished. Quote Link to comment Share on other sites More sharing options...
Allen Rowand Posted December 9, 2021 Report Share Posted December 9, 2021 Nice work! Looking forward to seeing the finished mod. Quote Link to comment Share on other sites More sharing options...
Trey Posted December 9, 2021 Author Report Share Posted December 9, 2021 I got the boom pole cup finished. Worked out pretty well I think! I am glad that I foresaw the castor hitting the cup, and made it removable! Still folds (Pretty much) as it should. Holds the boom very secure! Quote Link to comment Share on other sites More sharing options...
