Nathan B Posted December 21, 2021 Report Share Posted December 21, 2021 Hello I have been looking for a transparent panel like in acrylic that I could mount in front of my Smartview duo as a protection. It would be something as simple as this : but see through! I can't find it anywhere Thank you in advance for your help Best, Nathan B. Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted December 21, 2021 Report Share Posted December 21, 2021 tap plastic? tapplastic.com Quote Link to comment Share on other sites More sharing options...
Nathan B Posted December 21, 2021 Author Report Share Posted December 21, 2021 2 hours ago, Dalton Patterson said: tap plastic? tapplastic.com Thanks for this! Are you familiar with this website? You think a cut to size Extruded Acrylic would do the trick? There's many different types Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 21, 2021 Report Share Posted December 21, 2021 A local hardware store can cut an acrylic panel to your desired size (they usually carry different thicknesses). Drill four holes and mount it. If you screw the mounting screws in too tight it might crack the panel, so exercise some caution. Quote Link to comment Share on other sites More sharing options...
ivanovich Posted December 22, 2021 Report Share Posted December 22, 2021 2 hours ago, John Blankenship said: A local hardware store can cut an acrylic panel to your desired size (they usually carry different thicknesses). Drill four holes and mount it. If you screw the mounting screws in too tight it might crack the panel, so exercise some caution. This! I use dual lock so I can remove it when I need to. You’ll just need dimensions for the HW store to cut the right size. Quote Link to comment Share on other sites More sharing options...
Nathan B Posted January 2, 2022 Author Report Share Posted January 2, 2022 Ended up using tapplastic.com They cut it to size and added 4 holes. Only $40, very happy about it. Quote Link to comment Share on other sites More sharing options...
