jawharp Posted January 26, 2022 Report Share Posted January 26, 2022 I wanted to upgrade the talkback mic on my Cooper 106 since the internal one sounds like hot garbage. I figured I'd use the Ext. Slate xlr jack on the side of my mixer to plug in an old lav to use as my mic so I can run it wherever I wanted. Can I just wire it to an XLR male and feed it phantom from the Cooper through the XLR jack? The datasheet from Tram says that the TR-50 supports 48v phantom. If so, does anyone know how I would wire that? I know there are positive and negative bias trams, but I'm not sure if that would affect how it would get wired. Thanks Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted January 27, 2022 Report Share Posted January 27, 2022 You would need a XLR Phantom Pwr supply adaptor, if a wireless lav is wired directly to PP it will fry the mic. The Tram TR-79 Phantom Pwr supply would work. but it is a bit over priced IMO. Lower cost alternatives are plentiful though, Quote Link to comment Share on other sites More sharing options...
jawharp Posted January 27, 2022 Author Report Share Posted January 27, 2022 Aaah, okay. Do you know how many volts that tram power supply lowers the phantom to? Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted January 27, 2022 Report Share Posted January 27, 2022 Most XLR Phantom Pwr adapters transform 48v (or whatever) to the bias current lav mics need (typically 3 to 5 volts). As I recall.. the Tram TR-79 can also be powered by a LR44 (3v button cell battery) when Phantom Pwr is not available. Quote Link to comment Share on other sites More sharing options...
