Sebi Posted February 21, 2022 Report Share Posted February 21, 2022 I just discovered that Neumann is about to launch a new miniatrue clip mic system. It seems like they're mostly aiming at musicians but who knows how it will perform as a plant mic? Cables are available for all tx systems (3.5mm/Lemo/Mini-XLR/XLR). So far, there's only one capsule with a cardioid pattern. Capsule is priced at $299 and a whole set for a specific instrument application with gooseneck, clip-on and XLR-adapter comes at $699. Don't know if this will have any value on set or advantages over common plant mic solutions but I thought I might just share it. There's also probably people on the board who record music every once in a while. https://www.bhphotovideo.com/c/product/1687662-REG/neumann_8707_mcm_114_set_high.html/overview (no affiliate-link whatsoever, just attached the first link I found since there isn't that much online yet...) Quote Link to comment Share on other sites More sharing options...
igomarsound Posted February 21, 2022 Report Share Posted February 21, 2022 yes saw that as well, it looks promising, especially as a plant mic. Should be available in spring 2022 But like you said it's 100% aimed at the music / live scene... Curious to hear and see how it goes for us on set. as soon as the rental companies near me got some, i'll definitely try them to see how it performs Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted February 21, 2022 Report Share Posted February 21, 2022 In addition to the cardioid pattern, the sensitivity spec is low (3.4mV), so it's application is limited to close micing and high SPL sources Quote Link to comment Share on other sites More sharing options...
Mungo Posted February 23, 2022 Report Share Posted February 23, 2022 On 2/21/2022 at 5:53 PM, Rick Reineke said: In addition to the cardioid pattern, the sensitivity spec is low (3.4mV), so it's application is limited to close micing and high SPL sources And 152 dB max SPL. Seems definitely designed for brass and strings not for thin voices 😞 Quote Link to comment Share on other sites More sharing options...
