788t fails working on Li-ion batteries
jimmycat
Hi,
   My old but reliable 788t stopped working with any Li-ion batteries I put in, no more power-drawing, no more power-charging. The circuit seems just dead. The batteries themselves all work fine on other devices. The unit still runs well with external V-mount batteries, but I just feel worried running it without a bridging power source as a protection.
   Has anyone had the same issue?
I had that issue early on there is a power transitor that blows..it was a fairly easy fix by SD..sounds like the same issue maybe..also there is a relay for the internal batts ..you can hear it click if you listen closeky when you select internal batt charge..the relay may be an issue?..
I see you are uk based..No not easy to diy fix..call Kris Jarosv krisaudioservices@gmail.com
London based..does UK Sound Devices repairs highly recommended and carries spares for Sound Devices..Kris looked after my 788t along with a lot of other 788t users .
Very reasonably priced
