Robp Posted March 28 Report Share Posted March 28 Hello all, I have been trawling through component websites looking for a DC power plug with the following dimensions; 2.1mm inner diameter 5.5mm outer 12mm barrell length (mating depth) I only seem to be able to find 2 on the internet. The switchcraft is good but quite expensive, and I have no need for the locking ring. The tensility is a bit rubbish. https://www.digikey.co.uk/en/products/detail/switchcraft-inc/767K/2749239 https://www.digikey.co.uk/en/products/detail/tensility-international-corp/55-00051/8626992 Does anyone happen to have any links for such a thing? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
rich Posted March 28 Report Share Posted March 28 i use these https://cpc.farnell.com/pro-elec/jr8306a-2m/lead-dc-extension-2-1mmr-a-2m/dp/PW01940?ost=pw01940 cut the female end off at the length of your choice and put your chosen connector on. Quote Link to comment Share on other sites More sharing options...
Robp Posted March 29 Author Report Share Posted March 29 1 hour ago, rich said: i use these https://cpc.farnell.com/pro-elec/jr8306a-2m/lead-dc-extension-2-1mmr-a-2m/dp/PW01940?ost=pw01940 cut the female end off at the length of your choice and put your chosen connector on. Thanks for the link, are the barrells 12mm long? These cables don't seem to have a proper data sheet. There are a few scenarios where a replacement connector is the only solution - i.e. replacing the connector on a power supply Quote Link to comment Share on other sites More sharing options...
rich Posted March 29 Report Share Posted March 29 i just measured them and the barrels are 12mm long. ive never been happy with the power connectors that you were looking for initially. the cable clamp never feels particularly effective, or cuts into the outer coat of the wire, which is never good for a power connection. if its for a power supply, an option might be to fit a 4 pin XLR to the power supply, then make a 4 pin XLR to the cable i linked to. Quote Link to comment Share on other sites More sharing options...
