jwill Posted March 30, 2022 Report Share Posted March 30, 2022 I presently running an SRC 941 and been loving it, considering 2nd SRC same block. Are there any potential issues that I should consider? OR....would a Wideband A1 or B1 be a better option? I also run the dcht/dchr combo in A1 for a camera hop, also use a block 19 smv in IFB mode to feed my IFBue setup! I look forward to your thoughts and opinions. Thanks Quote Link to comment Share on other sites More sharing options...
Shastapete Posted March 30, 2022 Report Share Posted March 30, 2022 If you only plan to use it in the States, then it'd probably work great for you. I'd only suggest a lower frequency if you intend to travel internationally (but local regulations would dictate what's usable there anyways) Quote Link to comment Share on other sites More sharing options...
