Marc Wielage Posted December 11, 2009 Report Share Posted December 11, 2009 Have a look at this disc space calculator in the support pages Sound Devices has put together: http://www.sounddevices.com/calculator/index.html It answers card capacity questions. How much you record in a day is a question only you can answer. Somebody should make this an iPhone app! --Marc W. Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted December 11, 2009 Report Share Posted December 11, 2009 Somebody should make this an iPhone app! --Marc W. There is this Dashboard Widget for the Mac: http://puter.a-no-ne.com/hiro_tools/dawCalc Best regards, Jim Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted December 12, 2009 Report Share Posted December 12, 2009 Terrific! Thanks, Jim... [rushing off to download it] Wish it was an iPhone app, though... --Marc W. Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted December 12, 2009 Report Share Posted December 12, 2009 Terrific! Thanks, Jim... [rushing off to download it] Wish it was an iPhone app, though... --Marc W. Hey Mark, I forgot about another disc space calculator Widget. It will calculate recording time available by number of tracks, sampling rate and bit depth and allows you to set disc space aside for all the mounted drives on your Mac. It's called audioSpacePro 1.3 Quote Link to comment Share on other sites More sharing options...
Derek H Posted December 12, 2009 Report Share Posted December 12, 2009 Any word back on the marred-finish on the carbon-composite plates issue that cropped up a few posts back? Quote Link to comment Share on other sites More sharing options...
Petros Kolyvas Posted December 12, 2009 Report Share Posted December 12, 2009 Any word back on the marred-finish on the carbon-composite plates issue that cropped up a few posts back? I was told by Sound Devices that they were working on a fix and that, when they had an acceptable solution, I would be contacted to arrange to have my mixer repaired. Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted December 12, 2009 Report Share Posted December 12, 2009 save this link as a shortcut on your Home screen on the iPhone. http://sounddevices.com/calculator/mobile.html Better yet! Best regards, Jim Quote Link to comment Share on other sites More sharing options...
TimPitot Posted June 18, 2010 Report Share Posted June 18, 2010 I have been using my 552 for the past 12 days, got lots of radio mics and am finding some channel 'bleed' ie when I have a channel faded down, sometimes I can hear (very faintly) what is coming in to that particular channel. This is more noticable when a radio is out of range and I am getting hits/splats on it. Only solution seems to be powering down the offending radio. Also, when feeding timecode into the mixer, i have noticed a very, very low level on the L meter when monitoring is set to record source. Nothing is audible in the headphones. Just wondering if anybody else has experienced these issues or has any thoughts. Quote Link to comment Share on other sites More sharing options...
Harris K Posted June 19, 2010 Report Share Posted June 19, 2010 In terms of SVEN, I've only used the 552 for two days, but a quick go through the cheat sheet and I had the thing set up and didn't need to check again. SVENs voice is annoying and fairly difficult to understand, but it's ultimately better than setting up a 302 or 442. Granted, the 552 has more settings requiring adjustment, but I can't see myself changing any of them too often. With a 302 or 442 you simply can't adjust settings without a cheat sheet or practice, which can be a real hassle. SVEN is a step in the right direction, but I'm in no hurry to buy "SVEN reads the works of Joyce" Quote Link to comment Share on other sites More sharing options...
Matt McGowin Posted June 19, 2010 Report Share Posted June 19, 2010 This has probably been mentioned before, The SD 442 is pretty straight forward. It has multiple main outs and direct outs. You do not have to make any changes with the "cheat sheet" very often. The only change that I can think of that you would need to change is the outout level for feeding to camera. Or perhaps setting the battery level for the type of power that you are using or something else that I cant remember right now , but you dont ever have to go into the menu on a daily basis. Im pretty sure the 552 is the same but it gives you more options that you have to confirm with SVEN. Correct me if Im wrong/sorry for jackin the thread Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted June 19, 2010 Report Share Posted June 19, 2010 Im pretty sure the 552 is the same but it gives you more options that you have to confirm with SVEN. There is nothing in the 552 menu structure that requires you to use SVEN. If you don't like him, take the headphones off and use the cheat sheet or the manual to make your menu selections. There are a few things that you need SVEN to do that I can think of off-hand: Setting the RTC, Record time remaining and file/folder navigation. Quote Link to comment Share on other sites More sharing options...
Rob Lewis Posted June 19, 2010 Report Share Posted June 19, 2010 Has anyone heard the Wendt X5 type bleed through when the faders are closed? I have heard reports of this from a couple of mixers. I personally have not experienced this with my 552. Quote Link to comment Share on other sites More sharing options...
Derek H Posted June 21, 2010 Report Share Posted June 21, 2010 Rob, I have heard some bleed but only in extreme situations. Like when one of my RF channels breaks through the squelch with a wall of noise. Even then you need to be really listening for it. In the field you may not notice it. That's been my experience. best, -derek Quote Link to comment Share on other sites More sharing options...
