Adam Aslan Posted May 12, 2022 Report Share Posted May 12, 2022 How do I fix?  😕  seems like a screw fell out.…  anyone know which screw it is?  lectro ucr211 block 26 still kickin butt in NYC! IMG_8157.MOV Quote Link to comment Share on other sites More sharing options...
Dean Slotness Posted May 12, 2022 Report Share Posted May 12, 2022 See details here on fixing the loose XLR/door on the UCR401 and other products:Â The battery door on my UCR receiver is loose. How can I tighten it without taking the receiver apart? (lectrosonics.com) Â Quote Link to comment Share on other sites More sharing options...
Adam Aslan Posted August 21, 2023 Author Report Share Posted August 21, 2023 using a 1mm allen and nothing is happening  do i need that extra .27mm to get the magic to happen? Quote Link to comment Share on other sites More sharing options...
Matthew Steel Posted August 22, 2023 Report Share Posted August 22, 2023 At that size wrench, I'd say the 0.27mm could be significant. Seems like an undersized wrench might turn the screw if it is loose enough but then slip. I imagine you might be able to tell by feel if that is happening.  I haven't had one of these open, so I'm guessing here - If your door operates properly and the XLR housing is firm, then I'd say there is a second screw that just holds the insert into the housing. I expect that second screw, if it exists, would be the standard flat head screw with reverse threads that holds all Switchcraft inserts. Quote Link to comment Share on other sites More sharing options...
edward chick Posted August 22, 2023 Report Share Posted August 22, 2023 Send to Lectro. They have a quick turnaround. Quote Link to comment Share on other sites More sharing options...
Matthew Steel Posted August 23, 2023 Report Share Posted August 23, 2023 Or since you're in Brooklyn, JayCee Communications might be a good alternative. Quote Link to comment Share on other sites More sharing options...
