mark kirchner Posted May 29 Report Share Posted May 29 Sennheiser MKE2 Repair This MKE2 lavalier microphone had a broken solder joint at the capsule. If the capsule was twisted the signal would go from normal audio to pops and clicks with no audio. I decided to cut away the plastic housing. As expected, one of the solder joints had broken. I soldered the connection and the microphone worked as normal. Next I took some strong black nylon thread and wrapped the end of the black cable. I used a “snelling knot” that fishermen use to snell a hook. I wanted the nylon to bite into the cable to help the epoxy hold tightly to the cable. Then I painted on clear 5 minute epoxy, covering the nylon and the solder joint. A second coat of epoxy was done, this time the capsule was rotated to help the epoxy creat a nice round shape. This made a similar durable replacement for the original plastic housing that cut away. The epoxy could have been tinted black with model paints. Good luck, Mark Kirchner Quote Link to comment Share on other sites More sharing options...
