noe Posted Sunday at 11:59 PM Report Share Posted Sunday at 11:59 PM I am trying to setup my mixpre 6 to record discreet ISO tracks for an MS rig (input 1: M, Input 2: S). Ideally I would like to listen to the decoded MS on my headphones, but still record the discreet tracks (to decode MS later). I have done this with a 788T in the past but I am somehow not finding a way to do it with the mixpre. I tried setting up the HP Preset selecting MS, input 1 for the L channel and input 2 for the right channel... Also tried with L in L and R in R (and MS selected). No matter what I select I always hear both sides of the S signal in the same side of my headphones. How (on earth) does one listen to the MS decoded on this mixer? I am sure there is a simple way I cannot see right now. I may be tired but I cannot figure it out and can't find a step by step guide anywhere. Any help would be much much appreciated. Quote Link to comment Share on other sites More sharing options...
TVPostSound Posted Monday at 12:41 AM Report Share Posted Monday at 12:41 AM Do not link Channels Record Raw Mid and raw side HP preset= set ISO1 left , ISO2 right- toggle MS button on lower right to on. What Mic (s) are you using? Quote Link to comment Share on other sites More sharing options...
noe Posted Monday at 07:52 AM Author Report Share Posted Monday at 07:52 AM Thanks TVPostSound, I am using schoeps mk41/mk8. Mk41 to input 1.. Mk8 to input 2. I have the channels unlinked and have set the HP preset as you suggest. If I Pan the Input 1 (mid) to the left and input 2 (side) to the right, I hear both microphones on both sides in my headphones. However, I cannot perceive a stereo image created with the side mic. Speaking to either side of the microphone is heard on both sides and the recorder does not seem to distinguish/decode Left&Right signals coming from the mk8. Is this how it is supposed to be? I am more used to ORTF and spaced omni stereo imaging, which feels very clear on cans. Quote Link to comment Share on other sites More sharing options...
Throwback Posted Monday at 08:08 AM Report Share Posted Monday at 08:08 AM You have two options; either (as TVPostSounds suggests) just let the HP option do the decode (which was the only way originally with the Mixpres); or, which became possible with a firmware update a couple of years ago, link the channels (i.e. '1-2MS') and then go to Menu>Inputs and where it says 'MS Decode' select 'Mix only'. ISO will be the M and S channels unmatrixed, and the mix and the HP will be LR. Works really well. Cheers, Roland Quote Link to comment Share on other sites More sharing options...
noe Posted Monday at 12:07 PM Author Report Share Posted Monday at 12:07 PM Thanks Roland & TVPostSounds. Both things seem to work well now. I think I had a gremlin messing with me. Quote Link to comment Share on other sites More sharing options...
Throwback Posted Monday at 01:40 PM Report Share Posted Monday at 01:40 PM Good to hear. I must admit I stopped using an MS decode HP preset once the MS decode submenu was added to the inputs back in 2018 (firmware 2.20): I guess if you were using very mismatched mics (in terms of sensitivity) you could adjust the gain if not linked, but when linked using the channel 2 fader knob (width) changes the relatively levels anyway, and, of course, if the MS decode is to the mix only you have the pre-fader M and S channels as isos. It is nicer to be able to change the LR width for the mix/monitoring with a single fader knob using the MS linking. Cheers, Roland Quote Link to comment Share on other sites More sharing options...
noe Posted Monday at 03:26 PM Author Report Share Posted Monday at 03:26 PM Thanks for the detailed note and the reasoning behind your approach, Roland. I see what you mean. It also feels like changing the HP preset requires a lot more fiddling with the menu when switching back and forth from MS to any other mic configuration. I am going to go with linking and decoding MS only in the mix. It looks like I can keep my HP in stereo LR and switch faster to the spaced omnis or ORTF if I need to. *I do need to remember to roll off channel two before switching back to unlinked... Quote Link to comment Share on other sites More sharing options...
TVPostSound Posted Monday at 06:31 PM Report Share Posted Monday at 06:31 PM 10 hours ago, Throwback said: You have two options; either (as TVPostSounds suggests) just let the HP option do the decode (which was the only way originally with the Mixpres); or, which became possible with a firmware update a couple of years ago, link the channels (i.e. '1-2MS') and then go to Menu>Inputs and where it says 'MS Decode' select 'Mix only'. ISO will be the M and S channels unmatrixed, and the mix and the HP will be LR. Works really well. Cheers, Roland Thats how I do it, (option 2) but wasn't sure of the OPs firmware, so I just gave basic settings. Quote Link to comment Share on other sites More sharing options...
