Parker Brown Posted July 9, 2022 Report Share Posted July 9, 2022 Hi everyone, I've been tapped for a last minute job and am trying to send AES digital channels from two QRX200s through the XL-AES into my 833. The XL-AES is installed and the expansion port on the 833 is turned on. Each channel allows me to select 1-8 XL-AES inputs. The QRXs have AES digital enabled on 1/2 and 3/4. AES output rate is Normal. AES outputs are set to Normal (split) and each of the two ta5 connectors is plugged into a ta3 on the XL-AES. I'm getting nothing. Test tone from the QRXs appears on none of the selected XL-AES inputs and neither does audio from a transmitter. The 833 is version 6.1. Any help would be hugely appreciated. Parker Quote Link to comment Share on other sites More sharing options...
Parker Brown Posted July 9, 2022 Author Report Share Posted July 9, 2022 I've confirmed the QRXs are outputing digital audio as I can hear the signal through the analog inputs when I turn AEs on. I think it's the 833/XL-AES that's not hearing the signal. Quote Link to comment Share on other sites More sharing options...
Parker Brown Posted July 9, 2022 Author Report Share Posted July 9, 2022 Solved. My cables were wired incorrectly. Nothing like a nice day of deductive trouble shooting. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted July 9, 2022 Report Share Posted July 9, 2022 The AES on a QRX is at 32Khz. Does the 833 AES inputs support that sample rate? Try setting the Sony F5 AES to ON and see if it makes a difference. I believe this will set the QRX to ouptu 96Khz instead of 32Khz Quote Link to comment Share on other sites More sharing options...
