polemonkey Posted January 9, 2010 Report Share Posted January 9, 2010 Is "23.98" just another way to say "23.97"? Are they the same thing? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted January 9, 2010 Report Share Posted January 9, 2010 " You can use 29.97ndf and get the exact same results " careful... maybe, maybe not! both of the non-integer frame rates are .1% slower than the integer frame rates, dividing the same 'stretched out second'* by either 24 or 30. thus they are both the same rate, but not exactly the same thing, which may make a difference in use, just as 24 FPS is not exactly the same as 30 FPS, but they are both dividing up the same "exact" (clock) seconds up by either 24 or 30. 23.976 is the exact rate of 24 FPS slowed down by .1%, but is often expressed "rounded up" to 23.98 (29.9700000 is 30 FPS slowed down by .1%) * the last frame is completed, but that takes it into the following (clock) second! Quote Link to comment Share on other sites More sharing options...
