osa Posted September 28, 2022 Report Share Posted September 28, 2022 Do they make a Straight lemo mini 5pin for alexa mini L/R input vs the right angle, and if so does anyone know a part number? First time i ran into this where some gadgetry was mounted on cam blocking the up-right angle plug so i had to go timecode only, but that is how they preferred anyways. Would like to have the option in the future if a connector is available Quote Link to comment Share on other sites More sharing options...
rich Posted September 28, 2022 Report Share Posted September 28, 2022 fgg.0b.305.clad42 the d42 bit tells you the type of end at the cable and cable diameter. if you want the longer body connector for some reason, swap the first F for a J. here are loads of options if you have a lot of time to kill. https://web.lemo.com/PartSearch?app=&mat=&ref=fgg.0b.305&lang=en Quote Link to comment Share on other sites More sharing options...
osa Posted September 29, 2022 Author Report Share Posted September 29, 2022 Thank you this is great for future reference! found the arri prewired straight connector seems to be my best option so i can throw what i need on the other end pretty easy Quote Link to comment Share on other sites More sharing options...
