Does anyone know what the correct wiring would be for a Deity w.lav Micro for both servo and non-servo Lectrosonics (5-pin) transmitters? The cable is 2 wire.
I know that their DA5S microdot adapter works best for me on both my Lectro SMWB and UM400 (not A) transmitters.
I can't seem to take apart their microdot connectors to see what magic is happening inside.
  • 7 months later...
Quote
Hi Blocktek, This is the DA5S:
Thank you Vincent.
It matches Lectro "compatible" "2V positive BIAS, 2 wire" (fig.1, just slightly different resistors),
so I guess it could be also wired as "servo" "2V positive BIAS, 2 wire" (fig.9)... with signal to pin 3 and shield to pin 1.
--> Anyone tried?
  • 1 year later...
  • 2 weeks later...
On 4/3/2025 at 8:41 PM, Daveydddd said:
Hey Fernando, did you ever wire this up? If so, what did you wind up doing?
Not yet, but I have to rewire a W.Lav Pro with a faulty microdot to TA5f pretty soon.
First surprise is that the mic has 2 wires plus shield (thought it had 1 + shield).
I assume that, for modern servo wiring (as in fig.9), shield and white must go to pin1, and red to pin3.
The mic cable is not nice to work with; it has those ultrathin wires inside (common in some headphone cables) that you can't really peel, you have to solder them directly...
15 hours ago, Blocktek said:
The w.lav Micro is 2 wire. The Pro is 3. I bought the resistors to rewire my Micros, but I haven't had the patience to work with that tiny wire.
Thanks for confirmation : )
Still think fig.9 wiring should be the right one for both the Micro and the Pro. It is the "servo" version of fig.1 wiring, which matches DA5S adapter for a "compatible" wiring for both the Micro and the Pro...
Of course, help/confirmation from anyone with first hand experience, incl. Deity, would be much appreciated
