Deity TC-1
Michael Kocab
11 hours ago, The Documentary Sound Guy said:
What I noticed is that I couldn't set the yy:mm:dd:uu format in the app at all.  Maybe you have a more recent version, and this is a bug in the app?
What version of the app & TC-1 firmware are you on?
iOS app version: 1.2.1
Firmware version: 1.8 (2022-12-16)
Yes, all available preset formats in the app are without UB (yy/mm/dd, dd/mm/yy or mm/dd/yy), however, user bits are always the last two characters, which you can edit manually. Because of a bug, they’re output as the first two.
15 hours ago, EMP said:
Hi everyone,
Just wanted to share a bug I found on TC-1. User bits set in Sidus Audio app are being output in the reverse order.
For example, if you set UB to yy:mm:dd:uu in the app, TC-1 will output uu:dd:mm:yy. Confirmed with Zoom F8n Pro and Tentacle Sync E.
Not sure if this issue is with the TC-1 or Sidus Audio app.
Did anyone notice this as well?
Hi @EMP, confirmed. We are working on it, we have a solution already, final stages of testing at the moment.
  • 2 weeks later...
Just broke my first TC-1.  Cracked screen.  This is not a fault of the unit; it's definitely an L&D situation due to on-set abuse, but having a screen definitely creates a failure mode that doesn't otherwise exist, which isn't something I was thinking about when I bought it.
The unit still functions fine, so it's really just cosmetic (for now, anyway).
Now to find out what Deity's repair options are like.
2 hours ago, The Documentary Sound Guy said:
Just broke my first TC-1.  Cracked screen... Now to find out what Deity's repair options are like.
I'm thinking that with the app, you don't really need the screen. I've been using the app daily just to set TC on my Scorpio with the MASTER unit that lives in my bag.
I hope they can fix it for you at a reasonable cost. Please keep us posted!
Tim
Even without the app, the screen is functional enough.  I prefer not being dependent on an app, and my normal workflow doesn't use it.
My bigger worry is long-term longevity once the screen is cracked.  I'm kind of expecting the screen to come off in bits, and it's probably not as water resistant as before.
I would try applying a smartphone hard screen protector cut to TC-1 screen size. Might just hold the cracked glass together.
  • 2 weeks later...
I'm afraid this hasn't been a good experience so far.  I e-mailed their support two weeks ago.  Heard nothing, so I bugged them after a week.  This did produce a response asking for a photo of the damage and some particulars about the item.  I send it promptly.  Since then, nothing.
So, to sum up, it's been two weeks since I first enquired, and I still don't know whether they can repair it, despite sending them the information they requested.
I'll keep bugging them, but this isn't stellar service.
