Redco TSG-1 vs TSG-D1
I have been using Redco TSG-1 cable for audio bag interconnections for a number of years based off of Eric Toline’s recommendation.
I’m going to be connecting AES wireless to a Sound Devices XL-AES and see that Redco now carries a digital cable TSG-D1.
I’m wondering if this is a different cable from the TSG-1 and if I can just use the non-digital cable on a very short run?
I’ll probably call Redco but they aren’t open until Tuesday.
Any ideas? Thanks.
The TGS digital cable has a lower conductor to conductor capacitance. That can play a significant difference dependant on signal frequency and length of run.
Likely better to query Sound Devices for your use case.
I will say from my personal experience i used to be a hyper-stickler about analog cable for analog and digital cable for digital but as long as your making cables for bag or cart not 25’ or long cables etc i have found that standard analog cable works perfect for digital runs. I used mogami thin cable for multi pin digital i/o 24” max and zero issues
