Tom Maloney Posted June 23, 2010 Report Share Posted June 23, 2010 Hi all, hope this is the correct forum for the post. I have an older MXP 290, works very well.....except the CH R fader is starting to act up on me. I don't really use the aux 1 & 2 outs, so could I just swap out the faders or is there a better solution. Don't think I could get parts for this old machine. I have not pulled of the cover yet. Thanks Tom Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted June 23, 2010 Report Share Posted June 23, 2010 Hi all, hope this is the correct forum for the post. I have an older MXP 290, works very well.....except the CH R fader is starting to act up on me. I don't really use the aux 1 & 2 outs, so could I just swap out the faders or is there a better solution. Don't think I could get parts for this old machine. I have not pulled of the cover yet. Thanks Tom While you might get an answer here, I would suggest asking at R.A.P. (rec.audio.pro) a google group that covers studio sound and gear. Eric Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted June 25, 2010 Report Share Posted June 25, 2010 Another good studio sound group to talk to about mixer parts is Gearslutz: http://www.gearslutz.com/board/ --Marc W. Quote Link to comment Share on other sites More sharing options...
Tom Visser Posted June 25, 2010 Report Share Posted June 25, 2010 I used to have an MXP-29, which had developed a problem with one of the monitoring boards and at the time, made the decision to dispose of it after making a quick attempt at repair. I got tired of assembling and disassembling the unit trying to isolate the problem and didn't really feel like spending too much time on the surface mount boards. I believe our mixers are / were very similar. If I remember correctly, the faders were cheap Alps units - or perhaps made in Japan in-house units, not sure now... which is fine, as I think both boards are VCA designs. With a taper boards, I would expect the fader to contribute to degradation in operation over time and need regular service and potential replacement. With VCA designs, sure the fader can exhibit issues and need cleaning / replacement, but I would expect an increasing probability of an electronic problem, and may not be solved with a simple fader swap. The insides are tight and not as accessible to work on as I would have liked. Given the value of that mixer, I personally would say take a pass, but your tech abilities (and patience) may be better than mine. I see quite a few MXP-S390 go around on eBay, probably the same family of parts, Sony has long since discontinued service and support on these. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 25, 2010 Report Share Posted June 25, 2010 If you like the mixer you might contact a good tech and have them look at it--esp if you have schematics or service manuals. They can give you a ballpark estimate for a fix, and then you can decide how much you REALLY like that mixer. Philip Perkins Quote Link to comment Share on other sites More sharing options...
