Mikro Addict Posted February 20, 2023 Report Share Posted February 20, 2023 What is the best way to convert faders 3, 4 and 5 which takes line level, into mic level. A pad cable? Cheers, M Quote Link to comment Share on other sites More sharing options...
codyman Posted February 20, 2023 Report Share Posted February 20, 2023 You've got it backwards. Channels 4-6 need a "hotter" input (line level). If you want to hook up a mic level source to those channels, you need a mic preamplifier such as the Kortwich: https://www.shop-ftt.de/de/vcp-m3 If you're in NYC, Gotham Sound carries them. Quote Link to comment Share on other sites More sharing options...
Mikro Addict Posted February 24, 2023 Author Report Share Posted February 24, 2023 Thanks for the info. Oh boy that is pricey. Is there an amplification cable that can be built? I wonder what a line level input is good for. Quote Link to comment Share on other sites More sharing options...
PMC Posted February 24, 2023 Report Share Posted February 24, 2023 Line level input at the mixer is good for wireless mic receivers set to line level output. All of my Lectro SRb receivers feed my SD664 with line level (+6). As do my old Senn G3 receivers (+12) when I need 12 wireless. The only thing I need mic level input is for booms, plants, multbox. Amplification cable? Yeah, no. Quote Link to comment Share on other sites More sharing options...
Mikro Addict Posted February 24, 2023 Author Report Share Posted February 24, 2023 This very useful , PMC. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted February 24, 2023 Report Share Posted February 24, 2023 Quote Is there an amplification cable that can be built? - Not really (unlike a line-to-mic cable which only requires a couple of low cost resistors to attenuate the signal), mic-to-line needs a complex circuit with some kind of power sourse. Quote As do my old Senn G3 receivers (+12) The Sennheiser G series EK 100 portable receivers (with AF set to the max +12) will feed a line level.. but it will be a little anemic feeding Sound Device's +4dB inputs.. Quote Link to comment Share on other sites More sharing options...
Soundwil Posted February 25, 2023 Report Share Posted February 25, 2023 With my 633 I used (on channels 3-6) one of these because my Audio Ltd 2040 receivers pump out mic level only. From Kortwich: http://www.filmtontechnik.de/en/products-from-kortwich/vcp-preamp/ Specifically the preamp-M3 für Sound Devices 633. Quote Link to comment Share on other sites More sharing options...
Phillip C Dent Posted February 25, 2023 Report Share Posted February 25, 2023 I’ve looked into the kortwich as well as the pink noise 3 channel expander. The problem with either of those setups is that you’ll lose your pre-fade isos which is a dealbreaker for me. I’ve run into this same situation when I want to run my 664 in 12 channel mode. I could put an analog board in front of channels 7-12 line inputs to use as a control surface, but I would lose my pre fade isos. I would love to have a CL-12, but those are like hens’ teeth these days and I don’t know of any other control surfaces for the 6 series recorders. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted February 25, 2023 Report Share Posted February 25, 2023 22 minutes ago, Phillip C Dent said: I’ve looked into the kortwich as well as the pink noise 3 channel expander. The problem with either of those setups is that you’ll lose your pre-fade isos which is a dealbreaker for me. I’ve run into this same situation when I want to run my 664 in 12 channel mode. I could put an analog board in front of channels 7-12 line inputs to use as a control surface, but I would lose my pre fade isos. I would love to have a CL-12, but those are like hens’ teeth these days and I don’t know of any other control surfaces for the 6 series recorders. I run a 664 rig for music work mostly, and for inputs 7-11 have an SD 552. The prefade direct outs of the 552 feed the 664 7-11 inputs at trim level, and the post fade stereo mix out of the 552 goes onto the mix bus of the 664 via Link i/o. This way I end up with prefade isos on 11 channels of the 664 while still being able to make a live mix that doesn't affect the isos. Quote Link to comment Share on other sites More sharing options...
Phillip C Dent Posted February 25, 2023 Report Share Posted February 25, 2023 Thanks Philip P! I did not know the link i/o worked like that with the 552. That is a great solution. I’d rather have the CL12 but the 552 is a great work around. Maybe I can find one relatively cheap. Quote Link to comment Share on other sites More sharing options...
BAB414 Posted February 25, 2023 Report Share Posted February 25, 2023 12 hours ago, Phillip C Dent said: Thanks Philip P! I did not know the link i/o worked like that with the 552. That is a great solution. I’d rather have the CL12 but the 552 is a great work around. Maybe I can find one relatively cheap. I used to do the same with the Solice Mini. Doesn't need to be a 552. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted February 25, 2023 Report Share Posted February 25, 2023 You can do this with any device that can make separate prefade outs per input and also make a mix out on the main faders. Link i/o works well with older SD gear but could work with any mixer if you get the mix level you are sending to the 664 dialed in. My current rig fits in a PortBrace AO bag with other stuff (NOT wearing this, it sits on a cart) and has similar-feeling and operating knobs to the 664. You do have to remind yourself that you solo all channels on the 664, not on the external device! Quote Link to comment Share on other sites More sharing options...
Phillip C Dent Posted March 1, 2023 Report Share Posted March 1, 2023 The 664 manual mentions that the link i/o will work with a 552 and another 664. I wonder if it will work with my old 442. Quote Link to comment Share on other sites More sharing options...
Derek H Posted March 2, 2023 Report Share Posted March 2, 2023 Sure, I think the pin out is in the manual and you can make it work with anything. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted March 2, 2023 Report Share Posted March 2, 2023 Yes the manuals for the 664 and the 552 give the pinout for hooking them with a 442 up via link i/o. Quote Link to comment Share on other sites More sharing options...
