vizualize Posted February 28, 2023 Report Share Posted February 28, 2023 Hi, does anyone have experience with the workflow of scorpio and just the x+? I am trying to find something online without any luck. I prefer the more compact size of x+ and don't need the d2 screen, I will just use it as an old style mixer fader. Any knowledge will be appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
rich Posted February 28, 2023 Report Share Posted February 28, 2023 i havent tried it with my scorpio, but with my 888, i just plugged in the USB only (no power) and it worked without doing much else. i tried using 12v power, but the faders behaved weirdly, so unless you need the flying faders, dont bother with a power cable. Quote Link to comment Share on other sites More sharing options...
vizualize Posted March 1, 2023 Author Report Share Posted March 1, 2023 9 hours ago, rich said: i havent tried it with my scorpio, but with my 888, i just plugged in the USB only (no power) and it worked without doing much else. i tried using 12v power, but the faders behaved weirdly, so unless you need the flying faders, dont bother with a power cable. Thank you, so you mean that the x+ faders will change gain without the power connection? I received a message from SD that the x+ might not work at all without the m+, if it is working as a fader controller this is exactly what I need, the rest can be done through the Ipad app. Best Regards Quote Link to comment Share on other sites More sharing options...
r.paterson Posted March 1, 2023 Report Share Posted March 1, 2023 Check out Wave Fit for scorpio as an option, approved by SD current firmware. https://www.waves.com/hardware/fit-controller-for-emotion-lv1 Quote Link to comment Share on other sites More sharing options...
vizualize Posted March 1, 2023 Author Report Share Posted March 1, 2023 12 minutes ago, r.paterson said: Check out Wave Fit for scorpio as an option, approved by SD current firmware. https://www.waves.com/hardware/fit-controller-for-emotion-lv1 Thank you for suggesting but it is big and heavy and it needs 220 volts to power. I am looking for a light portable option Quote Link to comment Share on other sites More sharing options...
rich Posted March 1, 2023 Report Share Posted March 1, 2023 4 hours ago, vizualize said: Thank you, so you mean that the x+ faders will change gain without the power connection? I received a message from SD that the x+ might not work at all without the m+, if it is working as a fader controller this is exactly what I need, the rest can be done through the Ipad app. Best Regards i have just tested to confirm. if i connect my X+ to my 888 via USB only, the X+ powers up (including the D2 display) and fader and gain control works fine. Quote Link to comment Share on other sites More sharing options...
vizualize Posted March 1, 2023 Author Report Share Posted March 1, 2023 5 hours ago, rich said: i have just tested to confirm. if i connect my X+ to my 888 via USB only, the X+ powers up (including the D2 display) and fader and gain control works fine. Thank you very much, I will get one myself It will be great if and when you have time to upload a video or photos. I guess it could be helpful to anyone who is trying to get a small and working controller. Cheers Quote Link to comment Share on other sites More sharing options...
Fred Salles Posted March 2, 2023 Report Share Posted March 2, 2023 On 3/1/2023 at 3:54 PM, rich said: i have just tested to confirm. if i connect my X+ to my 888 via USB only, the X+ powers up (including the D2 display) and fader and gain control works fine. Thanks for that. I did not know you could do without the 12v dc external input. I assume you mean that you do not use the motors of the fader, if that is the case how do you change bank? Could you try to measure the power drawn by the icon on your battery with that setup? That means 888 without it then with the icon plugged, then with the D2 as well? That would be very usefull as I have never found a real life situation report in the web on the current draw of the Icon solution on location. I also wonder if there is much difference in power consumption between the X+ and the M+, so if anyone using the M+ could chime in that would be great. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
rich Posted March 2, 2023 Report Share Posted March 2, 2023 correct. i do not want the motorised faders. they behave weirdly with my 888 - they jump to random positions and sometimes have a bit of resistance when initially moved. i dont change the fader bank. my M+ is a backup, and having fader banks doesnt seem practical for anything requiring a quick adjustment. if i needed more faders and i wasnt using my scorpio / CL16 setup, i guess id be using the faders for the additional channels on my ipad. 888 only powered up - 10.53W (16.2v 0.65A) M+ powered up via USB (no D2) - 11.63W (16.15v 0.72A) M+ powered up via USB with D2 - 12.25W (16.12v 0.76A) M+ powered with 12v and with D2 - 13.04W (16.1v 0.8A) Quote Link to comment Share on other sites More sharing options...
Fred Salles Posted March 3, 2023 Report Share Posted March 3, 2023 14 hours ago, rich said: 888 only powered up - 10.53W (16.2v 0.65A) M+ powered up via USB (no D2) - 11.63W (16.15v 0.72A) M+ powered up via USB with D2 - 12.25W (16.12v 0.76A) M+ powered with 12v and with D2 - 13.04W (16.1v 0.8A) Fantastic! Thanks a lot for that! So it is the M+ that you have , not the X+? Quote Link to comment Share on other sites More sharing options...
rich Posted March 3, 2023 Report Share Posted March 3, 2023 d'oh. it is the X+ Quote Link to comment Share on other sites More sharing options...
KenMartini Posted March 4, 2023 Report Share Posted March 4, 2023 I am using it with an 833. I power it and the motorized faders work great. Having the screen is a must. Quote Link to comment Share on other sites More sharing options...
Fred Salles Posted March 5, 2023 Report Share Posted March 5, 2023 (edited) 23 hours ago, KenMartini said: I power it and the motorized faders work great. Hello, I guess the motorized faders are power hungry, but there must be just a peak of power draw when you change bank I suppose. You say you power it, do you mean from external dedicated battery Or the same battery as the rest from your power distributor? Can you tell us more about the power consumption of it. Thanks edit: I just saw your post about your cart so one big PSC battery (very nice by the way 👍🏾) Edited March 5, 2023 by Fred Salles Quote Link to comment Share on other sites More sharing options...
