My 8 Bay BX1 chargers are now available (i forgot to post it)
Well many shipped by now but i thought i make a post anyway. since i forgot.
Picture is of Scott Farr's charging case. i dont have the fancy product photos i made with the Np50 yet.
Technical specification
  • Charges 8 BX1's Simultaneous.
  • Over sized Converter that can supply up to 2.5 times the current required, to run cool and increase reliability.
  • Matched Charging chips within 1% accuracy. (all pcb's are tested manually). 4.16-4.24 volt with a bias towards the lower end to achieve longer battery life.
  • Swiss made gold plated spring loaded battery contacts.
  • External power supply from a well known brand (Meanwell)
  • Passive cooling.
  • Ability to be fed by a DC power source between 12-48 volts DC (Cart battery or your Car, or a laptop brick)
Power supply specifications
Power
25 Watt
Input range:
85~264 Vac
Certificating:
CE
Cooling :
Passive
Protection :
Short circuit
Overload. Over voltage
Charger specification
Charge rate each slot simultaneous :
~500mA
Charge end voltage accuracy:
Within 1 % accuracy (all manually tested, and chips replaced if they did not meet this 1% criteria)
Protection :
  • Overheat Protection:
    Charger will cycle down charge current if module reaches above 65+- degrees Celsius.
  • Reverse Polarity Protection
  • Output over/under voltage
  • Over current protection
  • Short circuit protection
  • Thermal shutdown protection
  • Soft start
Size :
  • (HxWxL) 4.92 x 11.4 x 6.4 cm.
Weight
  • ~500 gram
more info and manual can be found here :  https://wrinex.com/product/wx-bx1-8/
or you could ask me of course :)
