Tom Visser Posted August 16, 2010 Report Share Posted August 16, 2010 FYI: the Neve portico is about $2k... I wanted to keep the high end theme going, to keep up with those upscale Whole Foods organic peas. Some say a generic pack from Foodland would serve the same purpose, but I'm sure the specific heat of the organic peas outperform the Foodland brand. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted August 16, 2010 Report Share Posted August 16, 2010 I believe an organic cooling medium is required to properly sink the heat away from any mysterium equipped electronics. Quote Link to comment Share on other sites More sharing options...
Paul Isaacs Posted August 16, 2010 Report Share Posted August 16, 2010 Don't know about 552 , but 788 does have digital domain limiters ( post fader (mix , auxiliry) ) so better check out how does it sounds without , also sd never tell us what settings that limiter ,if it acts as the pre fader or in any different way . that is essential as the mix bus if you use with cl-8/9 is what goes into the movie , Thanks Oleg - you are right. I forgot to mention that in addition to the analog input limiters, there are also limiters on each channel post-fade and also on the mix and auxillary mix busses. The limiter settings are global - they affect pre-fade, post fade and mix busses. Paul Quote Link to comment Share on other sites More sharing options...
Zack Posted August 17, 2010 Report Share Posted August 17, 2010 I believe an organic cooling medium is required to properly sink the heat away from any mysterium equipped electronics. haha Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 17, 2010 Author Report Share Posted August 17, 2010 haha USELESS comment. waisted my time checking this tread. Quote Link to comment Share on other sites More sharing options...
Zack Posted August 17, 2010 Report Share Posted August 17, 2010 USELESS comment. waisted my time checking this tread. Ah bummer, now I feel the same way. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 17, 2010 Author Report Share Posted August 17, 2010 so i can guess that 552 has digital domain limiter as well ? I guess so. Jon Tatooles should join the conversation. Quote Link to comment Share on other sites More sharing options...
Jim Gilchrist Posted August 17, 2010 Report Share Posted August 17, 2010 I guess so. Jon Tatooles should join the conversation. Paul Issacs is Principle Applications Engineer at Sound Devices, so he's probably qualified to answer your questions. Here's the press release announcing his joining the company. Best regards, Jim Quote Link to comment Share on other sites More sharing options...
jon_tatooles Posted August 17, 2010 Report Share Posted August 17, 2010 I guess so. Jon Tatooles should join the conversation. I took the bait. The digital section of the 552 is after the analog section, including mixing. Analog limiting for both the input limiters and bus limiters (there are seven limiter circuits in a 552). Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 19, 2010 Author Report Share Posted August 19, 2010 What about the 788t? Analog or digital limiter? or both? I took the bait. The digital section of the 552 is after the analog section, including mixing. Analog limiting for both the input limiters and bus limiters (there are seven limiter circuits in a 552). Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 19, 2010 Author Report Share Posted August 19, 2010 Deleted the Zaxcom question. It was screwing up the statistics. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 20, 2010 Author Report Share Posted August 20, 2010 analog on pre , digital on post fader Yes thanks. It makes sense since : • Input Limiters can not be enabled for Digital Inputs. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted October 30, 2010 Author Report Share Posted October 30, 2010 Sorry for revisiting this post. Jon, How does the limiter work if using digital MKH8040 AES microphone? I took the bait. The digital section of the 552 is after the analog section, including mixing. Analog limiting for both the input limiters and bus limiters (there are seven limiter circuits in a 552). Quote Link to comment Share on other sites More sharing options...
jon_tatooles Posted November 1, 2010 Report Share Posted November 1, 2010 AES42 mics have to accommodate for preamp overload in the mic. I don't specifically know about the Sennheisers until I play with the one they gave us for AES. For the Schoeps, their gain structure is such that you can't overload them. The attached recorder is essentially a bit bucket for their AES stream. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 No it was just a general question about AES42 mics. what does rado mean if you can engage digital limiter after you rise the digital gain , what you can do as i understand only on the mix bus / aux but not on iso correct me if i wrong Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 Thanks Jon. I do not remember if I asked you before but here ago again: Any significant power diference between 48V and AES42? I guess my question is : Is AES42 more efficient then 48V AES42 mics have to accommodate for preamp overload in the mic. I don't specifically know about the Sennheisers until I play with the one they gave us for AES. For the Schoeps, their gain structure is such that you can't overload them. The attached recorder is essentially a bit bucket for their AES stream. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 1, 2010 Report Share Posted November 1, 2010 " Any significant power diference between 48V and AES42? " yes (check the mic spec's) also price difference for the mic's! Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 Senator real world experience with the 788t specifically: Schoeps cmd2 vs cmc6 in the 788T. And I am asking the manufacturer Jon! " Any significant power diference between 48V and AES42? " yes (check the mic spec's) also price difference for the mic's! Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 Reading the "white paper" means nothing. How companies implement the technologies is what is important. " Any significant power diference between 48V and AES42? " yes (check the mic spec's) also price difference for the mic's! Quote Link to comment Share on other sites More sharing options...
chriskellett Posted November 1, 2010 Report Share Posted November 1, 2010 Senator real world experience with the 788t specifically: Rado - That is just SMM's way of saying he does no know, pay it no mind. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 I respect the Senator's ways. 95% of the time his philosophy is valid. Especially with new users. I blame myself for the question not being too clear. Rado - That is just SMM's way of saying he does no know, pay it no mind. Quote Link to comment Share on other sites More sharing options...
rich Posted November 1, 2010 Report Share Posted November 1, 2010 from looking at the specs and from hearing from zaxcom about using an aes42 mic wirelessly, the aes42 requires significantly more power than a traditional p48 mic. for example. the super CMIT requires 170ma at 10v or 1.7Watts the CMIT5U requires 4.4ma at 48v or 0.2 Watts so the super CMIT is almost 10 times more power hungry, though as it generates a bit of heat, im sure it will do fine in very cold conditions ;-) cant say ive particularly noticed any significant change in battery life when using the super CMIT, though as i am using a 788, which is a power hungry machine anyway, i'm less likely notice. i still get through 2-3 lithium np1s in a typical day. as well as the price difference, there is also the features offered. the noise cancelling with the super CMIT or dynamics and remote control with the some of the Neumann mics. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 1, 2010 Author Report Share Posted November 1, 2010 Not good. from looking at the specs and from hearing from zaxcom about using an aes42 mic wirelessly, the aes42 requires significantly more power than a traditional p48 mic. for example. the super CMIT requires 170ma at 10v or 1.7Watts the CMIT5U requires 4.4ma at 48v or 0.2 Watts so the super CMIT is almost 10 times more power hungry, though as it generates a bit of heat, im sure it will do fine in very cold conditions ;-) as well as the price difference, there is also the features offered. the noise cancelling with the super CMIT or dynamics and remote control with the some of the Neumann mics. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 1, 2010 Report Share Posted November 1, 2010 " Not good. " what is not good?? the Super CMIT is a terrific product! the 788T is a terrific product! it took me less time to look up the same data as rich than it takes to type a reply, but I'm not into doing other folks' homework... as the 788T typically draws a lot more power, over 1 amp, the additional power of an AES 42 mic over a P48 (10ma max) mic will not be a major factor in typical battery life, especially if using digital input does actually reduce some of the current drawn by the circuitry of the recorder. Quote Link to comment Share on other sites More sharing options...
rich Posted November 1, 2010 Report Share Posted November 1, 2010 the super CMIT is great - i love how it can help with a/c noise, reverberant spaces and other noise beyond my control and i think the 788 is great as well, its perfect for how i like to work. but i have been fortunate enough to not have had the problems Oleg has had with his 788's. i hadnt considered the preamps not being powered when using the aes42 and looked at the overall power consumption, rather than just that of the mic. but not having the proper equipment to test it, i shall happily continue using my 788 and super CMIT until i use all my NP1's before the shooting day is done, then pine for my 442 and CS3e :-) Quote Link to comment Share on other sites More sharing options...
