NKL Posted April 10, 2023 Report Share Posted April 10, 2023 I’m thinking of switching over to IFBlue from my r1a and Comtek. But I use my R1a as a scratch track for camera occasionally. Could I use IFBlue to send scratch track to camera? Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted April 10, 2023 Report Share Posted April 10, 2023 Same as an R1a. Only plastic. And not made by Lectro. Quote Link to comment Share on other sites More sharing options...
Matthew Steel Posted April 10, 2023 Report Share Posted April 10, 2023 2 hours ago, Dalton Patterson said: And not made by Lectro. Although whoever manufactures it ultimately answers to Lectrosonics in some way, shape or form. Quote Link to comment Share on other sites More sharing options...
Michael Capulli Posted April 10, 2023 Report Share Posted April 10, 2023 I have them and are very happy with them. I've used them for camera scratch as well without issues Quote Link to comment Share on other sites More sharing options...
OB1 Posted April 11, 2023 Report Share Posted April 11, 2023 For those who have used both, is there a discernible difference(upgrade) from the R1A to the IFBlue (aside from the wideband)? My whole IFB/Comm workflow revolves around a dozen R1As across 3 blocks, signal boosted by SNA as needed. Does it make sense to move to IFBlue Quote Link to comment Share on other sites More sharing options...
codyman Posted April 11, 2023 Report Share Posted April 11, 2023 5 hours ago, OB1 said: For those who have used both, is there a discernible difference(upgrade) from the R1A to the IFBlue (aside from the wideband)? My whole IFB/Comm workflow revolves around a dozen R1As across 3 blocks, signal boosted by SNA as needed. Does it make sense to move to IFBlue I'd keep your R1a's for VIP's and then give IFBlues to clientside folks who want a "comtek" but don't ever bother even putting it on. Also, it is nice that they are multiblock. Quote Link to comment Share on other sites More sharing options...
Ian Thomson Posted April 11, 2023 Report Share Posted April 11, 2023 7 hours ago, OB1 said: For those who have used both, is there a discernible difference(upgrade) from the R1A to the IFBlue (aside from the wideband)? My whole IFB/Comm workflow revolves around a dozen R1As across 3 blocks, signal boosted by SNA as needed. Does it make sense to move to IFBlue I like the sound from an IFBlue more than an R1A when booming... might just be my headphones (Sony 7506), but it seems like a lower noise floor, and less fatiguing. 🤷🏻♂️ Quote Link to comment Share on other sites More sharing options...
Michael Capulli Posted April 12, 2023 Report Share Posted April 12, 2023 13 hours ago, OB1 said: For those who have used both, is there a discernible difference(upgrade) from the R1A to the IFBlue (aside from the wideband)? My whole IFB/Comm workflow revolves around a dozen R1As across 3 blocks, signal boosted by SNA as needed. Does it make sense to move to IFBlue Differences - lighter and more slim, AAs, programmable preset channels via LCD interface, better sound, As good if not improved RF performance in my experience and priced below R1A and its successor. If I were only buying a few for crew I'd go for the R1Bs just because I like the housing on those but I use M2Rs instead. It wouldn't fit my workflow to spread them across 3 blocks, but they are the same IFBs so you can use them how you want. Quote Link to comment Share on other sites More sharing options...
jwill Posted April 28, 2023 Report Share Posted April 28, 2023 What cable are you using to get from IFBlue into camera, is it mic or line level? Quote Link to comment Share on other sites More sharing options...
Fred Salles Posted April 30, 2023 Report Share Posted April 30, 2023 Has anyone tried them with a non Lectro transmitter? Is that even possible or the IFB compender /mode is Lectro only? Thanks Quote Link to comment Share on other sites More sharing options...
LarryF Posted April 30, 2023 Report Share Posted April 30, 2023 The IFB systems (Blue or Lectro) have a moderately narrow modulation acceptance of 20 to 25 kHz. If used with a common 50 kHz modulation transmitter they will spatter on peaks. Best, Larry F Quote Link to comment Share on other sites More sharing options...
LarryF Posted April 30, 2023 Report Share Posted April 30, 2023 On 4/28/2023 at 2:24 PM, jwill said: What cable are you using to get from IFBlue into camera, is it mic or line level? From IFBlue.com Audio output: 1V RMS into 50 ohms minimum Treat it as a consumer line level. It is a stout headphone level i.e.,+2 dBm. Best, LarryF Quote Link to comment Share on other sites More sharing options...
vin Posted May 1, 2023 Report Share Posted May 1, 2023 Dear Larry Why is 1V rms giving me 13 dBm at 50 ohms? Quote Link to comment Share on other sites More sharing options...
LarryF Posted May 1, 2023 Report Share Posted May 1, 2023 Your calculations are absolutely correct for 50 Ohms. Fifty Ohm values are typically used for RF levels since that is the most common impedance for RF devices and RF measurements. For audio levels, 600 Ohm levels were once the most common. Pro equipment still uses those values as a reference. That is what I did when I referred to 2 dBm, thinking of meter levels in a pro audio mixer or recorder. However, the most correct value for the Lectro IFB output is the 1 Volt into 50 Ohms specification. That is exact and has nothing to do with RF but is an average impedance value for most headphones that typically range between 32 and 80 Ohms. All this to say, the IFB will have the least self noise going into a line level input that has enough gain to match to low line levels of 0.1 to 0.3 Volts RMS. Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
Derek H Posted February 26 Report Share Posted February 26 Spam bot? Quote Link to comment Share on other sites More sharing options...
seth Posted February 27 Report Share Posted February 27 On 5/1/2023 at 8:16 AM, LarryF said: Your calculations are absolutely correct for 50 Ohms. Fifty Ohm values are typically used for RF levels since that is the most common impedance for RF devices and RF measurements. For audio levels, 600 Ohm levels were once the most common. Pro equipment still uses those values as a reference. That is what I did when I referred to 2 dBm, thinking of meter levels in a pro audio mixer or recorder. However, the most correct value for the Lectro IFB output is the 1 Volt into 50 Ohms specification. That is exact and has nothing to do with RF but is an average impedance value for most headphones that typically range between 32 and 80 Ohms. All this to say, the IFB will have the least self noise going into a line level input that has enough gain to match to low line levels of 0.1 to 0.3 Volts RMS. Best Regards, Larry Fisher Larry, can I ask why Lectro doesn't make IFBR1B with a switch to make it line-level and bypass the headphone jack? IFBR1b has to be the smallest transmitter on the market. I know a lot of cam ops would be happy about that. Quote Link to comment Share on other sites More sharing options...
codyman Posted February 27 Report Share Posted February 27 1 hour ago, seth said: Larry, can I ask why Lectro doesn't make IFBR1B with a switch to make it line-level and bypass the headphone jack? IFBR1b has to be the smallest transmitter on the market. I know a lot of cam ops would be happy about that. I'm beating a dead horse at this point but you could just use any of the Sennheiser G3/G4 receivers, turn off the pilot tone on them and voila, they pick up the Lectro IFB signal. Been using them for camera hops for years with the great reliability of the Lectro transmission (+ R1a's for video village etc picking up the same signal). Quote Link to comment Share on other sites More sharing options...
LarryF Posted February 27 Report Share Posted February 27 The headphone output is quiet and can be used as a line level (1 Volt) output. It is just lower impedance than most line level outputs, which is never a bad thing. I'm missing what is the reticence to use it as a line level output. (??). It's a minor point but G3/G4 receivers do not have matching equalization and compander time constants to the Lectro IFB. It certainly will work, though. Best Regards, Larry Fisher Quote Link to comment Share on other sites More sharing options...
seth Posted February 27 Report Share Posted February 27 The knob getting twisted, and I'm too ocd to just slap a piece of tape on it. I guess I could just take the knob off. Quote Link to comment Share on other sites More sharing options...
