Dave Pullmer Posted July 19 Report Share Posted July 19 Hello! I was curious if anyone had antenna reccos to improve the FM radio reception on my old receiver. Here is a photo of the antenna ports, any leads would be appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
codyman Posted July 19 Report Share Posted July 19 Does your unit have a built in antenna as well? My 2230 does and it seems to work fine here in LA metropolitan area. For an external, I'd just get a cheap 300 ohm off Amazon if you can place the end of it near a window. If you're dealing with a lot of metal or a long cable run, maybe stick with a 75 ohm one. Quote Link to comment Share on other sites More sharing options...
Matthew Steel Posted July 19 Report Share Posted July 19 If you are inclined to DIY, then for 75 ohm, try a coax whip like for wireless mics, with an appropriate length for the FM band; or for 300 ohm try a folded dipole like this one, https://hf-antenna.com/003/. I built a 300 ohm at one point for TV and it worked well enough, although the polarization is different between FM and TV (if that makes much practical difference). If it has no internal antenna, then I expect even a coat hanger would be a big improvement. Quote Link to comment Share on other sites More sharing options...
tourtelot Posted July 19 Report Share Posted July 19 How about the simplest 300 ohm dipole antenna that folks have been using on their FM tuners for years? I had one in the 70s, I have one now. https://www.amazon.com/AEDIKO-Antenna-300-ohm-Transformer-Receiver/dp/B097K3Y59N/ref=sr_1_13?crid=24J6YIK4DTNUD&keywords=Dipole+FM+antenna&qid=1689802932&sprefix=dipole+fm+antenna%2Caps%2C165&sr=8-13 D. Quote Link to comment Share on other sites More sharing options...
Dave Pullmer Posted July 20 Author Report Share Posted July 20 Thanks for the links everyone, appreciate it. The receiver is a SR4000, and it very well might have an internal antenna. I’ve got decent reception for some of our city’s main stations, but there are others that are too fuzzy for my liking. Which got me thinking, do certain radio stations pay more for higher transmitting power? I’d assume so based on my home/driving listening experiences… I’m also curious, why is it that a 75ohm antenna would do better close to the receiver, but the 300ohm would more than likely require being remoted to a window? Quote Link to comment Share on other sites More sharing options...
codyman Posted July 20 Report Share Posted July 20 This kind of breaks it down: https://www.radio4all.org/300-ohm-vs-75-ohm-fm-antenna/ Quote Link to comment Share on other sites More sharing options...
Dave Pullmer Posted July 20 Author Report Share Posted July 20 Sweet - thanks! Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted July 20 Report Share Posted July 20 3 hours ago, Dave Pullmer said: do certain radio stations pay more for higher transmitting power? Absolutely. Quote Link to comment Share on other sites More sharing options...
Dave Pullmer Posted July 30 Author Report Share Posted July 30 On 7/19/2023 at 2:43 PM, tourtelot said: How about the simplest 300 ohm dipole antenna that folks have been using on their FM tuners for years? I had one in the 70s, I have one now. https://www.amazon.com/AEDIKO-Antenna-300-ohm-Transformer-Receiver/dp/B097K3Y59N/ref=sr_1_13?crid=24J6YIK4DTNUD&keywords=Dipole+FM+antenna&qid=1689802932&sprefix=dipole+fm+antenna%2Caps%2C165&sr=8-13 D. This looks great! I’m curious, do you fully extend the antenna? It looks pretty big! Around 4.9ft when extended.. Quote Link to comment Share on other sites More sharing options...
tourtelot Posted July 31 Report Share Posted July 31 Yes. You pull out the "T-top" all the way. I hide mine behind furniture. Quote Link to comment Share on other sites More sharing options...
Dave Pullmer Posted September 14 Author Report Share Posted September 14 On 7/19/2023 at 2:43 PM, tourtelot said: How about the simplest 300 ohm dipole antenna that folks have been using on their FM tuners for years? I had one in the 70s, I have one now. https://www.amazon.com/AEDIKO-Antenna-300-ohm-Transformer-Receiver/dp/B097K3Y59N/ref=sr_1_13?crid=24J6YIK4DTNUD&keywords=Dipole+FM+antenna&qid=1689802932&sprefix=dipole+fm+antenna%2Caps%2C165&sr=8-13 D. Update - I found one of these kicking around in my house in a bag filled with rca cables etc, hooked it up and things are sounding crystal clear! it must have been my dads antenna he originally used with the receiver. good stuff though I don’t have the “T” fully extended. I’ve kind of snaked it around the sides of my turntable and tascam 4 track that I use to play tapes on. Not perfect antenna orientation but I figure still an improvement from no antenna at all. Quote Link to comment Share on other sites More sharing options...
