minister Posted December 11, 2010 Report Share Posted December 11, 2010 Hey gang, I think one of my Li-ion batetries went dead for my Sound Devices. It is an off-brand NP-F970 battery. I don't remember which one and the battery itself does not say. What happens is you install it into either a SD 702 or 744T and the light on the SD unit blinks for a bit then turns solid indicating that it is fully charged. When I disconnect AC, the unit will not power up. If I turn on unit with AC attached, then pull the AC, unit shuts off. My other 3 batteries work just fine. I am assuming that this is toast and I should just pitch it and get a new one. Anyone one have luck with re-conditioning these kind of batteries? Do people try to salvage these things? Or give them up for dead? Thanks in advance! Tom Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted December 11, 2010 Report Share Posted December 11, 2010 I am assuming that this is toast and I should just pitch it and get a new one. Anyone one have luck with re-conditioning these kind of batteries? Do people try to salvage these things? Or give them up for dead. Tom If you have a suitable charger that has a real conditioning/charge cycle that can be run, it certainly wouldn't hurt to put the "bad" battery through it and see if you can bring it back. It may of course actually be dead, toast as you put it, but I wouldn't write it off until you try and bring it back (unless it is such no name off brand that it was so cheap you should just throw it out). Quote Link to comment Share on other sites More sharing options...
minister Posted December 11, 2010 Author Report Share Posted December 11, 2010 Hi Jeff, Thanks for the response. I don't have a charger for this kind of battery. I only use the Sound Devices. I will do a search on your forum to see what discussions there are about Li-ion battery chargers. Quote Link to comment Share on other sites More sharing options...
