nyphotog Posted June 24, 2024 Report Posted June 24, 2024 I'm getting back into doing live news and will be buying a few Sony ECM-77B lav mics. For somewhat windy outdoor locations, does anyone have any recommendations for windscreens to pick up? Is the included metal windscreen good enough? How about the foam windscreens that Sony sells? Thanks! Quote
Maximumbass Posted June 24, 2024 Report Posted June 24, 2024 Outside you will need the foam minimum…and some furries when the wind picks up. Quote
nyphotog Posted June 24, 2024 Author Report Posted June 24, 2024 27 minutes ago, Maximumbass said: Outside you will need the foam minimum…and some furries when the wind picks up. Got it, thanks. Any recommendation for furries? Quote
SDsmixer Posted June 25, 2024 Report Posted June 25, 2024 18 minutes ago, nyphotog said: Got it, thanks. Any recommendation for furries? https://www.bubblebeeindustries.com/collections/the-windbubble-pro-1 Quote
nyphotog Posted June 25, 2024 Author Report Posted June 25, 2024 14 hours ago, SDsmixer said: https://www.bubblebeeindustries.com/collections/the-windbubble-pro-1 Perfect, thanks for the recommendation. Quote
