Fred Salles Posted August 19, 2024 Report Posted August 19, 2024 Hello everyone, Currently working on upgrading my cart I am searching for a solution for a single telescopic pole to attach to it, in order to carry the bar with up to 4 antennas. Now bear in mind that it must be light so preferably aluminium and with an anti twist system. I came upon one like that on a rented cart but cannot find any trace of it online so far. The anti twist was a kind of dent along the poles that prevent the poles from twisting within in each other and that was very convenient when operating in a windy weather. I have no idea what the brand was. I do not think it was Manfrotto. Thanks in advance for your suggestions. Regards Fred Quote
henrimic Posted August 19, 2024 Report Posted August 19, 2024 Hi Fred, I have installed this one on my cart. Very light, sturdy and easy to attach with pipe clamps. https://www.manfrotto.com/global/extension-for-light-stands-black-099b/ Quote
Nate C Posted August 20, 2024 Report Posted August 20, 2024 17 hours ago, henrimic said: I have installed this one on my cart. Very light, sturdy and easy to attach with pipe clamps. https://www.manfrotto.com/global/extension-for-light-stands-black-099b/ I use the same stand on my cart. When I switched carts I needed a pole that compressed to a smaller size than the previous Mafrotto stand I was using. Trade offs, it doesn't go quite as high and is slightly less sturdy. In practice this hasn't proven to be an issue. Very happy with it. Cheers Nate. Quote
Fred Salles Posted August 20, 2024 Author Report Posted August 20, 2024 Thanks Henri and Nate. it seems that is the only solution I am able to find in Europe for now. I think I will have to give up the version with the anti twist dent. Quote
Matthias Richter Posted August 20, 2024 Report Posted August 20, 2024 Manfrotto 1004BAC but without the base and first element. Still good hight left. Mounted to the side of my cart. Gives approx good 3 meters Quote
Fred Salles Posted August 21, 2024 Author Report Posted August 21, 2024 Thank Matthias. You can disassemble the base without permanent damage? I have the nanopole ms0490a that allows to remove quickly the "pole" section but I did not know some of their bigger stands allow that too. Quote
Matthias Richter Posted August 21, 2024 Report Posted August 21, 2024 if you open up the first knuckle thingy (not the red screw at the base) all the way you can pull out the poles. You are left with the base with a tube which I use as a tripod for my loudspeaker. Fits perfectly Quote
