Tascam Europe | Audio Recording Devices for Professionals and Hobbyists
https://www.tascam.eu/en/downloads/portacapture+x8
NEW Firmware v2.00
NEW Windows Settings Panel and ASIO driver v1.30
NEW iPhone App update Version 2.0.0
Date 18.09.2024
FIRMWARE
F/W V2.00 (September, 18 2024)
< New functions >
- MTR application "POCKET STUDIO" has been added.
- When recording in MANUAL mode, two mixes were recorded at the same time, but the user can now choose whether to record or not.
- EXPANDED PRE REC mode has been added to the prerecording function available when using the FIELD app.
< Maintenance items >
- When AUTO TONE was turned on and HOLD was selected immediately after recording started, AUTO TONE would not turn off. This has been fixed.
- When a confirmation pop-up "Is the AC adapter 1.5A or more?" appeared while a phantom power on confirmation pop-up was displayed, the phantom power on confirmation pop-up would disappear. This has been fixed.
- When mixing down large size files while connected via Bluetooth, the system would hang up. This has been fixed.
- Timecode synchronization stability with compatible Atomos products has been improved.
- When switching from the PODCAST app to another app, the recording format settings that were made prior to the PODCAST app are now restored.
- The display of remaining alkaline battery charge has been adjusted.
- Operation stability has been improved in other ways.
  • 3 weeks later...
Firmware v2.01 out:
F/W V2.01 (October, 8 2024)
- The following issues that occurred in the VOICE, PODCAST, MUSIC, FIELD, and ASMR apps have been fixed.
  - When the size of a file exceeded 4 GB during recording, recording would end without a new file being automatically created.
  - Recording would continue even after the time set for TIME FILE INCREMENT had elapsed.
https://www.tascam.eu/en/downloads/current/Portacapture%2BX8
  • 10 months later...
F/W V2.02 (July, 28 2025) out:
Latest information
The most recent versions of the firmware/software for this unit are as follows.
Firmware: V2.02 (Previously V2.01 updated at this time)
Remote control app
  Portacapture Control: V2.00
Software for Windows (ASIO Driver)
  TASCAM Portacapture Settings Panel: V1.30
We request that you always use the latest software/firmware version for this unit.
For information about the latest software/firmware, check the TASCAM Web Site ( https://tascam.jp/int/product/portacapture_x8/support )
FIRMWARE
- Overdubbing was not possible on audio tracks mixed down with the POCKET STUDIO app. This has been fixed.
- When editing audio files recorded on this unit with iZotope RX and then exporting them using "Export Regions to Files", 100 identical files would be created.
- When VOICE was the app that launched at system startup, the input audio would not be mixed in mono, and only the audio from the left channel would be recorded.
  • 5 weeks later...
F/W V2.03 (September, 8 2025)
- There was an issue where deleting a project mixed down with the POCKET STUDIO app would also remove other projects from the browse screen.
