Rycote PCS Boom Connector loose connection - Disassembly?
Hi, I was wondering if anyone has ever disassembled a PCS boom connector. One of mine does not lock as tight as it should any more. I've been using it in dusty environents, though hardly changing mics on it.
I have a lot of them and 2 broke after a long shoot. I email rycote but no positive answer from them.
They become giggly on the long run. But even though i prefer them to the ambient one's.
Let me know if you manage to fix it.
Thanks guys.
I did dis- and reassemble the unit, though without any change.
However, we have different versions around, a grey blueish and a darker blue greyish. I guess these are different batches.
Our darker ones all seem to have a less tight grip.
The mentioned screw is glued but can be loosened with enough force.
I guess it's user error? but I had two of them lock up on me and the last one caused me to miss a critical shot, so they were retired. Shortly after I helped a fellow mixer as 2nd boom for a large scene and he had the Orcas and they were fantastic. Very small and light, one hand function, and simple enough of a design that a lockup seems improbable.
Don’t let them snap onto a mic mount. That’s when they can lockup. Hold it with your hand a bit so that it locks a little slower.
Glad to hear the orca ones are nice. I tried the sound guy solutions cam style ones years ago which worked ok but I found that I liked the ambients better and also that’s what everyone else in town was/is using.
  • DanieldH changed the title to Rycote PCS Boom Connector loose connection - Disassembly?
On 11/18/2024 at 4:09 PM, DanieldH said:
Thanks guys.
Did it helped or not at all?
Was it hard to reassemble?
Not at all. I was hoping to find and remove a foreign body, but there was none.
Not hard at all. But I needed a second attempt to tighten the screw as the thread is quite tight.
