4 minutes ago, Fred Salles said:
I suppose you use omni mikes mostly with it?
No - cardioids will still give a forward facing (backward cancelling) pattern and may be chosen for 'front of stage' positioning for instance.
I do say I like the design: basically tough enough to stand on or take a prop fall ... I think I'd have the capsules a little further back myself (especially if using Schoeps...) but the photo illustrates the use nicely enough.
(Sorry Philip, still not answering your question)!   Jez
If you find these, I'd love to know where you get them.  Have you tried contacting Redding Audio?  They are the Schoeps distributor, they might have an in?
So far no go for a USA dealer (incl. Redding).  These are pretty expensive for what they are (like $300).  I think they would work well but would probably be a tougher sell to production at the lip of stages where they'd be silhouetted from the audience POV (vs PCC160 etc).   I wonder if someone has made a 3D printed knockoff or similar thing?
I'll suggest the other obvious - metal or wood with holes drilled in (for the sound) and foam (for the support). But for the quality suggested by the photo $300 is actually on a par or less than I would have originally guessed.
J
