Hi everyone,
For one DIY thing, I need to make an extension cable between my 4ch Wisycom MCR54 receiver and an SLK54-IK Superslot backplate.
I'm looking for an interconnect plug type that's used in backplates to connect to a PCB terminal on the bottom of the receiver, and wondering if it's some standard connector that I can buy separately, or did Wisycom design their own custom terminal.
Tried looking it up with Google lens but no luck...
Any insights?
Looks like It’s an of the shelf connector, would take some digging to work out exactly what thought.
A quick google of “pcb smd interconnector” I found this https://au.mouser.com/new/te-connectivity/te-connectivity-fine-pitch-btb-connectors/?_gl=1*j5y6tx*_ga*MTc5NTkzOTczNC4xNzM1OTg3MTk1*_ga_15W4STQT4T*MTczNTk4NzE5NC4xLjAuMTczNTk4NzIwOC40Ni4wLjA.
Looks like it’s a BTB (board to board) connector.
Good luck with your search!
  • 3 weeks later...
With just the provided photo to go off of, my guess would be a JST JMC connector. Closer photos and measurements would definitely help narrow it down.
Board-to-board connectors usually only come in PCB mount formats, so you'll either need to make a custom PCB to adapt to a ribbon cable, or design a flex PCB to accept the connectors and also be the "cable" itself.
