working on a trailer for a doc and ran into this issue (also ran into it back in mid december '24) curious if anyone has had a fix? we are making it by with multitrack .wav exports but if this was the whole feature length doc i imagine it would be a solid nightmare. embedded or sep files, omf vs aaf seem to be no difference. Comments on issues still as recent as 6hrs ago:
https://community.adobe.com/t5/premiere-pro-bugs/broken-omf-export-repeats-audio-clip-on-track/idi-p/15030720
The 2GB limit is for the "bento" or all in one type export.  We usually ask for the separate project file/media type OMF and then the file size limit isn't an issue.  We just received a very large Premiere OMF for a feature that opened w/o issues.
Hey Philip, do you know if they were using version 25 of Premier? This particular client is using the latest update which i believe is v25.1 I have not had this issue with other clients who have stayed with older versions.
sadly, this is a brand new glitch that repeats the same audio file over multiple edit points.
