Sound Posted July 11, 2025 Report Posted July 11, 2025 Hi everyone, I have a set of seven Sony UTX-B03 bodypack transmitters from the UWP-D series, and three of them have developed an intermittent connection at the minijack input (the classic "wiggle" issue). The audio cuts in and out when the cable moves, so I suspect the 3.5mm locking TRS connector needs to be repaired or replaced. Has anyone here already fixed this problem? How did you repair it? Were you able to find a genuine or compatible replacement minijack connector? Any tips on sourcing the spare part or advice on the repair process? Since multiple transmitters are affected, I’m especially interested in reliable sources for several connectors. I’d really appreciate any experiences, part numbers, or supplier recommendations. Thanks in advance! Quote
Conor Posted July 11, 2025 Report Posted July 11, 2025 Looks like these Switchcraft 35RAPC3BVN4 ex Mouser: https://www.mouser.co.za/ProductDetail/Switchcraft/35RAPC3BVN4?qs=IF7nv7MIRJ0XCKZtBNW8BA%3D%3D Quote
borjam Posted July 11, 2025 Report Posted July 11, 2025 Aha, I answered you on Reddit, but Conor's answer is much better, I wasn't aware of that Switchcraft part. Sony spares are expensive! If that is the correct part I would hoard several of them just in case! Quote
Sound Posted July 11, 2025 Author Report Posted July 11, 2025 7 hours ago, Conor said: Looks like these Switchcraft 35RAPC3BVN4 ex Mouser: https://www.mouser.co.za/ProductDetail/Switchcraft/35RAPC3BVN4?qs=IF7nv7MIRJ0XCKZtBNW8BA%3D%3D Fantastic! Thanks!!! 5 hours ago, borjam said: Aha, I answered you on Reddit, but Conor's answer is much better, I wasn't aware of that Switchcraft part. Sony spares are expensive! If that is the correct part I would hoard several of them just in case! Thank you as well for your help! Quote
Sound Posted July 14, 2025 Author Report Posted July 14, 2025 For a little more than a single sony spare with shipping I can get about 21 of those. So I will definitely take the risk. Thanks! Quote
Sound Posted July 24, 2025 Author Report Posted July 24, 2025 Oh no, it was the wrong one. The picture and descriptin on mouser were wrong. This one looks exactly like the broken part. Do you think its the right one? https://eu.mouser.com/ProductDetail/Same-Sky/SJ3-350122B?qs=IKkN%2F947nfDEdpuRs%2FVplw%3D%3D https://www.mouser.de/datasheet/2/1628/sj3_350122b-3511083.pdf Quote
borjam Posted July 25, 2025 Report Posted July 25, 2025 This part you linked is mono, and the 3.5 mm jacks used for these microphones are stereo. As for the Switchcraft connectors, there are several variants: Now, which Switchcraft reference did you order? I think the only one that makes sense is 35RAPC2BVN4 (stereo, three pins, no switching function) Quote
Sound Posted July 31, 2025 Author Report Posted July 31, 2025 I ordered 35RAPC3BVN4. But I got a totally different part. It has much more pins and not screw lock connector - see image attached. If I look at the data sheet of 35RAPC2BVN4 - the one you recommended, I think it has no screw lock as well, does it? The images on the product page always show a screw lock but "Images are for reference only See Product Specifications" - and there's no mention of a screw lock in the product details. I found out that the Sennheiser lock could be exactly the same, and its quite a bit cheaper than sony: https://spares.sennheiser.com/de-de/catalog/sparepart/573606 its about 8 euros compared to about 20 euros from sony. So maybe this part is the safer bet? Quote
Sound Posted August 1, 2025 Author Report Posted August 1, 2025 The Sennheiser spare worked out perfectly fine! I didn't think that it would be so easy! Thanks for all your help! Next time my cheap Sony lavs die I think I will rewire the input to sennheiser and use other mics. Guess I just have to swap the orange and red wire to do so? Quote
